Kind of heavy on your neck though, carrying those suckers around. Gonna use gaffer's tape to hold them on?
I already have a few ciems and iems. I don't need 5 or 10 of them just for a "different sound signature".
On my wish list:
Sound quality better then X5 +E12DIY with the configuration of E12a and Silmic capacitors
Low impedance to drive my AKG K3003 with 8 Ohms
Enough power to drive my Audeze LCD-2
Battery live time ~10h
USB 3.0
Tiny thumbnails with cover.jpg when open a folder
Physical volume knop like the first preview image
not on wishlist:
Ability to handle 30.000 mp3 files
Shuffle play
Wifi or bluetooth
I mean, keep it simple and do it well. I wouldn't spend my money for gimmicks, i prefer a high-end sound mashine for HiRes files, no less, no more!
X5 can already do the ones highlighted in bold. USB 3.0 not much use in audio and only good for faster data transfer from PC to DAP. Sound quality is very subjective especially about being "better". Tiny thumbnails is just software fix.
Except for the volume knob I guess you already found what you want with X5. :tongue_smile:
On my wish list:
USB 3.0
not on wishlist:
Shuffle play
Wifi or bluetooth
X5 can already do the ones highlighted in bold............. [snip]
Off topic but I can say the X5 has a hard time driving the LCD-2. Not subjective at all. They simply need more power to sound the way they are designed. If someone thinks they sound good straight from the X5 they are missing out.
You are right it's off topic. But I'm interested at the exact conditions you did the comparison. e.g blind, level-matched etc.
Fiio already confirmed that X7 will not run the same app-base as full android. Only enough apps that is audio/music related. So I don't think convergeance will happen as you are saying. I think it will be a mistake. Fiio has done good with the software side but it's a different league when you talk about full-blown Android.
If msata has a future in portables it must come out from the bigger android/ios market.
Niche market like DAPs run by small company like Fiio is a huge gamble. Especially it's the component with the least impact on sound.
