FiiO X7 | DXD | DSD | 384K/64B | ESS9018+ Android | WiFi | Bluetooth | 4 AMP modules | Balanced Out |
Mar 15, 2017 at 11:33 AM Post #16,936 of 18,020
  Q: Is it possible to use the X7 as a DAC for an iPhone?
There is a valid reason for asking this (honest).  Has anyone managed to do this and, if so, what was the cabling involved.
Many thanks.
I did, I used Apple Lightening to USB Camera adapter and a USB to microUSB cable. I never tried it for longer than few minutes but it was working fine on software 2.0 (have not tried on 2.x)
Mar 15, 2017 at 11:40 AM Post #16,937 of 18,020
Take a look at this, it may help... maybe a PM to poster?
http://www.head-fi.org/t/713735/fiio-x7-dxd-dsd-384k-64b-ess9018-android-wifi-bluetooth-4-amp-modules-balanced-out/11340#post_12523745
Regards
Nice - thanks Paulo (& ClassicGOD), I missed that post.
Mar 15, 2017 at 7:38 PM Post #16,938 of 18,020
  Anyone prefer Power Amp over Neutron, or visa versa? Will they both accurately play 24 bit audio?
ETA
I read that the S7 edge, which I have, is capable of playing HiRez audio, (which I cannot confirm) thus it's the phone I want the above players for.
I don't think ether will do native 24bit.
Mar 17, 2017 at 3:36 AM Post #16,939 of 18,020
I experience issues in 3.1.7 that did not occur with 3.1.6.
When the screen is locked and turns off, the player will not continue to the next song unless the screen is switched on.
Music stutters and stops to play randomly. That happens with all files.
So you can't listen to more than one song continuously... Makes the player totally unusable.
Mar 17, 2017 at 4:29 AM Post #16,940 of 18,020
Maybe reseting device or clearing FiiO app data?
I have 3.1.7 and its running smooth and flawlessly. No stutters and everything playing as expected, several hours a day btw.
One of the few things I would like still to be corrected are the track order inside playlists (created by app), it should respect the order of entry on the playlist IMHO - as an example, I rip two albuns and add to library for playing later so I create a playlist "New" and add them one at a time all tracks (Recently added list should be improved I don't use it) - later, the only option I have to play from the playlist is on A-Z order, AFAIR there are two icons, one for A-Z and other for ??? - they behave the same...
But back on topic, if you didn't already do a factory reset, clear database and delete the 2 FiiO app folders, reboot and rescan - I know a few people who did that and solved their problems permanently.
My 2 cents
Mar 17, 2017 at 5:47 AM Post #16,941 of 18,020
My 2 cents
thanks a lot for the suggestion. But how do I do that though?
Mar 17, 2017 at 6:34 AM Post #16,942 of 18,020
Hi, I use to be in "Pure Music" mode so I'll start from there:
Pure music mode
Swipe down twice
Settings
Scroll down to "Factory data reset"
"Reset Device" and wait for device to reboot...
Note: This doesn't erase music from internal storage
... after restart:
Android mode
Open FiiO music App
Cog wheel top left, scroll down...
"Reset Database"
Exit App
Open "ES Explorer"
Select top left tile "Internal storage"
Long press on "FiiOMusic" folder, it gets selected (green mark)
Select also the foder next to it "Imageloader"
Press the "Delete" icon bellow and delete both folders
Go back one step, select cleaner and clean recycle
Open FiiO app music, scan for songs, Scan all
My 2 cents
Mar 17, 2017 at 6:37 AM Post #16,943 of 18,020
Pure music mode
Swipe down twice
Settings
... after restart:
Android mode
Open FiiO music App
"Reset Database"
Exit App
Open "ES Explorer"
My 2 cents
Thanks a lot!
After resetting the device+deleting and rescanning DB it seems to work.
Mar 17, 2017 at 6:52 AM Post #16,944 of 18,020
Dear TomKorn,
Sorry to hear about that. Yes, please try to clear the data of FiiO Music from(Andriod mode--settings--app--all--fiio music--clear data) to see whether it helps? What about  switching to another play mode?
Best regards
Mar 17, 2017 at 7:13 AM Post #16,945 of 18,020
Thanks a lot!
Oh great!
I remember I had a similar problem after installing one of the last betas, I can't say for sure it was 3.1.7 but I did that reset and things been perfect since then.
Regards
Mar 17, 2017 at 7:57 AM Post #16,946 of 18,020
Official X7 beta firmware (Android 5.1) -- FW3.1.8_beta : http://fiio.me/forum.php?mod=viewthread&tid=42157&extra=page%3D1
The following changes and improvements have been made to FW3.1.8_beta compared to FW3.1.7_beta
1. Fixed issue where a scan may fail on too many songs with embedded album cover
2. Added the function of Play through Artist/ Genre/Album(turn ON the Play through folders)
3. Modified Album to be the default display choice under the list of Artist/Genre
4. Fixed issue where FiiO Music may exit abnormally when playing songs from other paths after playing DLNA songs
5. Fixed issue where incorrect display after removing and recovering the songs cover
6. Fixed issue where AIF files can not display album cover
7. Fixed issue where MCU may fail to update
Mar 17, 2017 at 8:21 AM Post #16,947 of 18,020
Hi,
There is an error in the download page? the download link says its for the "X7 Firmware upgrade tool with FW3.1.8 ... " but actually its a link for an OTA upgrade file.
[Edit] Anyway I didn't succeed to download yet. Downloaded.
regards
Mar 17, 2017 at 9:16 AM Post #16,948 of 18,020
Mar 17, 2017 at 9:30 AM Post #16,950 of 18,020
Hi, thanks for the new firmware, scannig ok, is it possible to remember the viper settings after reboot? When i turn of my x7, then turn on (or reboot) i must disable and enable viper settings (viper bass, fire equalizer, dynamic system) to make them work, also the dlna does not work from my synology nas... thank you
