Sound Eq
- Nov 9, 2013
anyone succeeded rooting a beta and installing v4a
Why is implementing gapless playback so difficult? It can't be the Android OS. My Android smartphone straight out of the headphone jack does gapless perfectly. The Onkyo DPX-1 supposedly does not do gapless within the players stock app either. And with all due respect to the member(s) who suggest using a third party app, even just temporarily, you are missing the point. I don't want to use a third party app, unless I want to use a third party app. Not to slag FiiO, or any other manufacturer for that matter, this is a basic function and should not be that much of an issue to implement regardless of cultural differences.
Some volume matched blind testing: Santana on Sennheiser HD650. iDSD micro vs Fio X7 + AM2 amp module with the help of Fiio HS2 to change between sources. I am unable to find any differences.
Since the FiiO HS2 is discontinued does anyone know of a similar item to the HS2 for about the same price?
am5Can someone tell me which Amp Module the SE output (SQ) of the AM3 is most similar to: AM1, 2, 2A, or 5?
I have all of those now and an AM3 will arrive in a couple of days. And two Black Dragon balanced cables. Oh, and an Onkyo Dp-X1A...Merry Christmas to me.![]()
Is it a card support issue? i.e. the X7 can't support a 256gb card.
Is it a card format issue? i.e. exfat isn't supported, and it needs to be FAT32.
My card/windows doesn't give me the option of formatting in FAT32, so I'd have to find a program that do it. Alternatively, where in the X7 settings menu is the ability to format the card? I couldn't find it.
