- Jan 30, 2011
Can you possibly upload the file - so those of us with X5's can test it on our devices?
OK - thanks. I've extensively tested myself comparing hi-res vs 16/44.1, and can't tell the difference. So for space and ease of use, my whole collection is 16/44.1 on the X5. Probably explains why I never have these issues.
I found a bug in the category browser with the 2.5 firmware. When browsing by Artist, if the album you pick is at the very bottom of the screen you will get all songs by that artist instead of just the album. The way you work around it is to scroll downward past the album so that it's positioned somewhere above the bottom of the screen and then scroll back up to select it. I believe that this issue may have been present in earlier firmwares as well.
Oh, and I'm still waiting for the "Album Artist" option.....
I can also advice you to do this. Even if there were differences, x5 is a portable device, taking high resolution with you on the go is... kind of a waste...
considering that those micro details that are better will usually be taken over by the noise from the outside world, your steps, ETC.
As an hq audio player it can just be used at home ... so thanks for the workaround but that doesnt solve the issue... Especially when it was working flawlessly with firmware before 2.4.. Gonna try reformat SD tonight... Did someone raise ticket to fiio?
I had tried to see if the artist bug also happens to me, it does not, one reason or another. How many albums do you have at most per a single artist?
It's if I have 8 or more albums by an artist. When I scroll down and select whatever happens to be #7 on my list, I get all songs by that artist instead of just the songs on that album.
I also use the X5 mostly at home. Great source to my different listening setups.
