Ekul61
- Jul 9, 2014
Thx for your advice. .. my amps on order. Will keep u posted
I keep trying to amp my x5 but keep coming back to it not amped. I tink solo it sounds betterYou don't need to amp the X5, its own amp is powerful enough to drive most headphones.
Also, combining the x5 with e 12 is better than the x5 with the e17. The e17 has the added feature of also being a DAC, but you can already use the X5 as a DAC, and the e12 is a superior amp.
My x5 just arrived last night and i tried it. I played flac musics 44.1khz/16bits and paired with my W60. Im not impressed with sounds. The separation is there but Treble is not good enough unlike with my ipod classic+e17 is noticeable. I try my ie80 the sounds makes difference good bass and treble but did not compete with my ipod+e17. The x5 needs to be burn to get the good sounding. If i pair it with the e12 does the sounds will be difference. My w60 is produce a very sounding with my ipod but in x5 i am little bit disappointed. What are the best music files for x5
