Fiio X5 - Custom/Modded firmwares
Aug 30, 2014 at 1:47 PM Post #331 of 2,615
FiiO once said they'd look into it. Can't recall if they ever came back to that, and what their answer was. You're not the only one having this problem though.
Lets hope its not been swept under the carpet, as the wheel drives me crazy most of the time as I ALWAYS go past where I want to be.
Aug 30, 2014 at 2:14 PM Post #332 of 2,615
Good to see I'm not alone... my chest literally tightens up in frustration whenever I go to use it.  I nearly just sent it back thinking I'd give the dx90 a try... but I'm trying to suffer through it.
Aug 30, 2014 at 2:19 PM Post #333 of 2,615
This was one of the first things that was brought to Fiio's attention but they have not acted on it just like many other requests.
Bugzilla looks like its dead and a waist of time posting there at the moment.
Aug 30, 2014 at 7:36 PM Post #334 of 2,615
My 'solution' has been to slightly press the wheel as I rotate. I find this helps control the action of my finger a little better, similar to how holding a camcorder to your eye helps stabilize things. Not perfect, but it works for me.
Aug 30, 2014 at 7:40 PM Post #335 of 2,615
+1 I use my X5 at least 2/3h a day minimum and too much of this time is devoted to bearing with this misbehaving wheel.
Sometimes i even take back the X3 to rest from this obvious mistake in the X5 design.
Fiio should communicate about it. If it's impossible to improve it by software then it should be said propery so we don't keep hoping and try to live with it.
Aug 30, 2014 at 8:08 PM Post #336 of 2,615
What type of problems are you having? I really have no issues navigating this.
Aug 30, 2014 at 8:40 PM Post #337 of 2,615
Good tip... I've tried to alleviate it by placing my finger at about the 5 o'clock position and then pulling down to 6..but still kind of a pain...
Aug 31, 2014 at 8:51 AM Post #338 of 2,615
The wheel has bumps on the bottom, and the case has dents, that's how it creates the "clicks".
These clicks are not at the same "speed" as the user interface, thus, one click sometimes makes you go to the next item, but sometimes it doesn't, and 2 clicks sometimes only make it go to the next item, or 2 items down.
Exactly. I prefer to know if something can't be changed, rather than waiting for a possibility that won't happen.
Aug 31, 2014 at 9:11 AM Post #339 of 2,615
I wonder if you were to put one of those bumpers on the outer diameter of the wheel and use your thumb/finger on the bumper to turn the wheel if that would help. just a suggestion. i will see if i have any from the portable amps if bought over the years.
Sep 19, 2014 at 9:37 AM Post #340 of 2,615
Howdy folks. Been away for awhile so I didn't realise firmware 2.2 was out officially. Gonna get to work on an updated Aztechno theme.
Also, I get messages occasionally from people asking if the can mod/alter my firmware, o which the answer is a resounding YES!
Go nuts!
Sep 19, 2014 at 1:42 PM Post #341 of 2,615
Go nuts!
Thanks man! Can't wait to see those lovely icons scrolling over my screen.
Oct 3, 2014 at 1:40 PM Post #343 of 2,615
Hey guys, any chance of getting a reverse scrolling modded version of the new 2.31 beta firmware?  I know it's beta but it opens up the library file limit to 20,000 from 5800.
http://www.head-fi.org/t/736163/need-help-to-test-the-20-000-sound-tracks-music-library-firmware-for-x5
Cheers and Thanks!
-HK sends
Oct 6, 2014 at 3:14 AM Post #345 of 2,615
