EvoFighter
- Aug 10, 2013
I am using a San Disk ultra 64 GB Class 10. Do you relly only have 128mb? Must be an older card then. Maybe this is causing the issue.
Keeping the downloaded songs should be normal app behaviour when updating.
Have you tried reinstalling the App or even resetting the Fiio to default?
opps... should be Sandisk 128GB Ultra Class 10.
Yes, by right it the downloaded songs should be still there after the app is updated, i have Spotify installed in my Note 3 too and never encounter this problem.
Yes, tried both - reinstalling the app and reset the Fiio to factory default. Anyway, I will try the second card slot and try another cards to double check everything. Thank you for confirming the Spotify Premium works perfectly with Firmware 1.1.0. At least I know it is not a firmware or app issue.
