DeLaw
- May 22, 2014
Using firmware, v 1.2.4, FiiO Music v. 1.1.0. US settings. Most all is working good with play back of flac and gapless,DSD gapless does not work and has small click between tracks. I converted DSD to 96-24 flac and all is fine. I mostly use folder play Artist/Album/Disc/Track 01-99. The artist name is in the right order and the back button work the way it should. The random play so far is perfect and the resume works also. This is all I have tested because that what I use most. The one thing I always do before updating is take the cards out, reset the database then update. Before I put the cards back in for scan I delete all files that are not needed on a computer to play the music. You need to have on view all files. Don’t know if it helps but it don’t hurt. I do not root cause I don't care to.
