There is no frequency change with the F9 going to balanced - I've measured them. And on the X5iii you don't get the same increase in voltage and overall power you get from most balanced set-ups. In fact you get slightly less. So lets look at the other specs.
Remember how balanced is always "cleaner", "darker", "more spacious", "wider sound-stage" .......
Lets look at cleaner first. SNR on SE is 115 dB and on balanced is 111 dB (actually worse). But both are beyond what we can hear - so no real difference. Both have THD+N measurements at 0.003% = well beyond our hearing. You'll get a magnitude more distortion from your earphones. Now the important one - crosstalk (channel separation). SE is 73 dB and balanced is 98 dB. That must make a big difference - right?
I'm going to quote something bookmarked a long time ago:
As you can see, SE crosstalk at 73 dB and balanced at 98 dB actually means nothing - we can't hear it.
What essentially happens is two things.
- People read the specs, and tell themselves balanced must sound better, and thats what they talk themselves into. In a blind volume matched test, they won't tell a difference.
- Most people don't volume match, and we are terrible at volume matching by ear (which is what a lot of people do). Most balanced circuits output a lot more power by design - therefore they are louder. People saying they hear a difference are often simply listening to one louder than the other. And we know louder is perceived as sounding better.
There are two other possibilities for differences:
- The balanced circuit actually sounds better by design (unlikely given FiiO's expertise)
- Impedance mismatch can affect frequency response for multi-BA driver set-ups (rarely happens with dynamics). You'll note the 1 ohm (SE) vs 3 ohm (bal) output. he F9 is 28 ohms, and as I said - no change in frequency response curves.
My advice - don't go balanced for the sake of going balanced, and not with the X5iii. The 2.5mm port is nice if you have a cable you prefer to use and it happens to be balanced. On the X7ii its a different matter as the balanced out is more powerful, and will actually drive 300 ohm headphones pretty well. So if you're planning on driving an HD600 for example - thats where the balanced on the X7ii would come in handy.
