Hi Fiio,
I disable the Play/Pause button when the screen is off to prevent accidental pressing of the button while I put the player in my bag. However, I experience that while the player is in screen off mode, the player can still be played if the Next or Previous button is being pressed.
In my opinion, this should not be the case. Can you help to fix it in the FW, such that the player can only beplayed using the Play/Pause button and not by pressing the Next or Previous button.
Thanks
Dear lwanism,
The next song would be played after pressing the pre/next button. It is designed to act like that. Some CD players also have this feature. If you don't need to play pre/next song, seems you won't need to press the certain button? Sorry if bringing inconvenience to you.
Best regards
