Yes, delete the UTWS5 from your phones bluetooth settings, keep bluetooth on. Reinstall the FiiO Control App but don't start it yet. Put both Hooks back in the case, hold the button in the case for 15secs, ignore the led flashing white-red and keep holding until the led on the case turns of, then let go of the button. After a few seconds the led should start to flash white-red again. Go into the FiiO Control App, grand all permissions and wait till it finds the UTWS5 (you can click on the refresh button in the App to find it, if it doesn't do it on its own). Once it has been found, click on it. Accept all pairing requests.I’m not able to connect Fiio Control App (1.1.4 ios) to UTWS5, been disconnecting/reconnect and re paired multiple times, but the app just prompt me back to the device selection.
Any solution?
