[FiiO UTWS5] True Wireless Bluetooth Earhooks as Usual,Coupled with Independent AK4332 DAC
Dec 10, 2021 at 2:40 PM Post #451 of 2,559
Has anyone ever used it with Campfire Solaris ?
I'm interested
Dec 10, 2021 at 3:06 PM Post #452 of 2,559
The battery is not great to start with at 8 hours (I assume at 50% Vol) it will tank with LDAC etc at "normal listening Volume range" which is 70-80% on most earbuds for me if outside.
Batteries store electric energy so you don't have to plug into a dedicated power source.
/s :stuck_out_tongue_closed_eyes:
Dec 10, 2021 at 8:54 PM Post #454 of 2,559
What has that got to do with anything I said? 😕
It means you are not forced to use LDAC. A lower level codec will offer better battery life than LDAC. Besides, 8 hours battery life is pretty common on TWS - IIRC, Apple airpods pro and Sony WF-1000XM4 offers similar runtime on normal use in a single charge. If you really want a lot more runtime, obviously a TWS setup is not going to suit you.
Dec 10, 2021 at 9:45 PM Post #455 of 2,559
Are you totally clueless (my last question was rhetorical) but this one is not?
FiiO is about sound quality and they have 8 hours at 50% Vol with lowest form of Codec so AAC/SBC, I would gather the selling point is the new Hi-RES codecs and the hope they add LDAC mentioned above which will give you even less esp. as no doubt 50% will not be that loud.
5-6 hours or such on any buds today no matter how good they sound is less than ideal IMO and that is without LDAC and say 70-80% Vol.
Earloops are larger so normally have more battery but I get they have a lot of chips inside these.
I do not need a lecture from you as to what I need or do not need as I do have a clue and the Sony XM4 were poor sound wise IMO and many her eand the battery did not even last that long esp. on one bud for many here.
I have more than one pair aptX Adaptive buds that have 10-15 hours and sound better than the Sony XM4 or L3P's or Edifier Neos did. again many here bought them and felt the same.
Dec 10, 2021 at 11:04 PM Post #456 of 2,559
Good for you then. So you are here only to be like an a**, I get it now. Sorry for the interruption, please continue.
Dec 11, 2021 at 3:31 AM Post #457 of 2,559
I'm not seeing a pic in the gallery but does anyone know if the 7Hz Timeless fits in the case?? Tnx...
drftr
I would be interested in this, as well. If anyone can reply, please?
Dec 11, 2021 at 10:59 AM Post #458 of 2,559
Dec 11, 2021 at 11:47 AM Post #459 of 2,559
Dec 11, 2021 at 3:13 PM Post #460 of 2,559
I just received a pair of UTWS5 yesterday and have been playing around with it. It's paired with the FH7s and an iPhone. When I am running Amazon HD, I noticed that the playback is only 16 / 44.1, whereas the track can be up to 24 / 96. When I am running AirPod Pros, it seems to play at least 24 / 48. Curious to know of this is a limitation from iOS or if I am missing something in the settings?
I've played around with the FiiO app, but its pretty barebones in terms of the ability to customize settings.
Dec 11, 2021 at 4:01 PM Post #461 of 2,559
I cannot help you with your query, sorry, bur can you please-please tell me how does it sound to you? I will be using a similar setup with the FH5s on my Android phone and Amazon HD. Also, how far away from your phone can you receive a good signal?
Dec 11, 2021 at 4:01 PM Post #462 of 2,559
I would assume AAC may have a higher bitrate on your iPhone+Airpods but not sure as do not own Apple products.
To get 24/48k on Android Amazon HD needs at least aptX-HD (24bit) which aptX Adaptive (24bit) does not fall back to so for Android users it will be aptX (16bit) if the phone does not support aptX Adaptive.
Amazon does not have a dedicated driver to bypass the 48k hard lock on Android so even if LDAC it is 24/48k, unlike PowerAMP and USB Audio Player which can by pass this for local files.
Dec 12, 2021 at 8:38 AM Post #463 of 2,559
How`s the ambient mode on these? Can anyone comment?
Dec 12, 2021 at 9:54 AM Post #464 of 2,559
Ambient mode is planned but has not been added to UTWS5 yet. Last official words are that we will get it in a few weeks if nothing goes wrong.
Dec 12, 2021 at 10:47 AM Post #465 of 2,559
oh, ok, I also read that Fiio was planning to add it - but I thought that had been happening already 😅 Thanks!
