pervysage
- Feb 19, 2013
So is LDAC implementation just a matter of time or is it never being implemented?
Sorry, Currently, LDAC, at the technical level, cannot be implemented on UTWS5So is LDAC implementation just a matter of time or is it never being implemented?
Dear friend,Does anyone have a problem with the UTWS5 when making phone calls with ambient sound on and the other party not hearing what they are saying? Firmware 1.42 phone Android.
I'm confused..Dear friend,
Does the right unit not be charged clearly? ..
My phone is Xiaomi MI 10 MIUI 12.5 and when I turn off ambient sound the problem disappears.Dear friend,
Does the issue disappear when ambient sound is off? And which mobile phone are you using? If you are convenient, please contact support@fiio.com about that.
Best regards
You probably put in the left hook first, then the right hook as the 2nd. Test it. It happened for me w the left hook when i put the left hook into the case first.Seems that I have the same problem but with left earhook, but my problem seems be worse due that I can not restart case pairing.... I press case button long time but nothing happen. It's like case internal software is hang or locked, Fiio, how we can power off this case if this thing happen. Wait to uncharge fully is a nightmare to try to solve is a nightmare. This case need a full power off button or contact to reset internal software....
On my right earhook I ear "power on" automatically every X minutes... but I never ear "power off" automatically... only "power on", "power on", "power on"....
Sorry, but how then Qudelix 5k (QCC5124) did implement support of LDAC?Sorry, BTA30PRO NOT support aptX adaptive
In order to support LDAC, there is no option that can support aptX adaptive.
Because aptX adaptive solution only QCC chip can support, and LDAC can only CSR8675 support, very difficult
Qudelix is a software powerhouse and official Sony partner. They actually helped Sony to develop the LDAC firmware for the QCC chipset from scratch so Qudelix can use it on the 5K (*Sony originally developed LDAC for CSR8675 only). All other manufacturers then get that firmware from Sony. Qualcomm on the other hand has little to no interest on helping any further LDAC development since they rather push for aptX Adaptive. That's the reason why you don't see particularly great LDAC support on QCC chipset, as Sony themselves doesn't invest enough into its development (on the QCC) while Qualcomm doesn't really want to help.Sorry, but how then Qudelix 5k (QCC5124) did implement support of LDAC?
