[FiiO UTWS5 2025/UTWS5] True Wireless Bluetooth Amplifier Is Officially Released!
Jul 2, 2022 at 1:11 PM Post #1,441 of 3,119
Hi there
I ve been using one for at least 100hs on an iPhone11
And as a rock /métal/HC « advanced listener » Im quite désappointed with the audio quality, whatever the IEM used (westone um20 w10 or w50)
It keeps the sound signature but just feeling compressed, less airy and dynamic than with std wires .
Especially on the w50 of course
But all the rest is just very good and no complain about it.
Si I il keep using it for everyday use (outside work) but wire the w50 for calm listening/environnement.
Maybe upgrading to a aptx HD phone could help..?
Jul 2, 2022 at 4:43 PM Post #1,442 of 3,119
Jul 2, 2022 at 5:16 PM Post #1,443 of 3,119
Jul 2, 2022 at 7:47 PM Post #1,444 of 3,119
Jul 3, 2022 at 9:29 PM Post #1,445 of 3,119
Feedback:
Please, make the pulsating of the round LEDs faster in the next update! Make them blink! The pulsating is so slow that after i close the box lid.. i have to stay there for a while just to see if it is pulsating or not. It should be visible immediately if the round LEDs are pulsating or if they're steady on.
Edit:
Here is a photo. Why doesn't it charge? I had to open the lid and close it again and then it started to charge. Happens all the time! Lid is 100% flush closed!
Each time i close the lid i have to check the LED to see if it is charging or not.
Dear RouZah,
Thanks for the kind feedback. We will record and report to the product manager and engineer for assessing about that.
Best regards
Jul 3, 2022 at 9:31 PM Post #1,446 of 3,119
@FiiO same question here, any plans for a UTWS7 with LDAC or even aptX Lossless? If so, around when, please?
Dear Nick24JJ,
Thanks for your interest in our product. We haven't heard about related information from the product manager. Will share with you when there are any update.
Best regards
Jul 4, 2022 at 1:40 AM Post #1,447 of 3,119
Hi guys.
I'm using a UTWS3 paired with FD5 and I just wished it had custom eq for a pinch of bass boost and I read a few months ago that that UTWS5 will have after an update. Does it have it yet? I won't buy it just for Fiio's promises :).
Jul 5, 2022 at 11:44 AM Post #1,448 of 3,119
So this just happened:
I let the UTWS5 charge over night. I opened the case today in hope of listening music for some hours:
1. The right hook had sound for a second then turned off.
2. I turned it on again. It said "Power on". Then it turned off again.
3. I pressed a few more times on the button of the right hook, but it didn't turn on.
4. I though to myself "Naahh not again! Did it discharge again?"
5. So i put both hooks back into the case, then connect to fiio app to see if the non working hook had any charge.
6. The right hook was not even visible in the app.
7. I let the hooks charge for 1 minute, then i took them out of the case again. And looked at the fiio app to control their charge level.
8. Look at screenshot. The right hook indeed had no charge.
-- This is not the end though. Then THIS happened: --
As i put both hooks back into the case for them to fully charge up.. the LEFT hook would not charge! The right hook (which was first invisible, then had 0% charge after a minute ..started to charge without problems). I pushed down on the L hook (the 64% charged one) and opned closed the lid.. to no avail. After a few tries of opening/closing the lid, then the left hook started to charge, as well, which means that the round left LED started to pulsate, too.
What to do? Change my device? I will mail the fiio shop in my country and see what's up. If a new device will do the same, then there 's no point and maybe an update only fixes this.
Jul 5, 2022 at 10:32 PM Post #1,449 of 3,119
Dear RouZah,
Sorry to hear about that.
And did you try to clean the charing contact of the unit to check again?
Best regards
Jul 6, 2022 at 3:31 AM Post #1,450 of 3,119
Dear RouZah,
Best regards
During a month of using I have not noticed any correlation between contacts cleaning and charging robustness.
Jul 6, 2022 at 10:13 AM Post #1,454 of 3,119
Sounds familiar to me. It's always one hook, not both.
It's very strange because while listening to music the battery doesn't drain that fast. It only happens when it is turned off, either inside or outside the case.
Anyway, I have already started the process to return the product. But email support never responded.
edit:
Jul 6, 2022 at 11:14 PM Post #1,455 of 3,119
edit:
Dear littl3viking,
Sorry to hear about that. You could try to restore to default settings from the setting menu of FiiO UTWS5 page to see whether the issue remains?
And if the seller could replace it for you, hope the replacement does not have the same issue.
Best regards
