[FiiO UTWS5 2025/UTWS5] True Wireless Bluetooth Amplifier Is Officially Released!
Sep 23, 2021 at 5:50 AM Thread Starter Post #1 of 3,151
FiiO
Sponsor: FiiO
Guangzhou,China
Compared to the last generation, the #True Wireless Bluetooth Amplifier UTWS5# is the first ear hook model that is equipped with an independent low power consumption DAC, the AK4332, all over the world. The built-in amplifier comes with more excellent performance, lower noise floor yet higher SNR. Thanks to the nearly 40% improvement in output performance, we are able to start our HiFi wireless Bluetooth journey!
On September 28, 2021, #FiiO 2021 Autumn Launch Event II# will straightly get to you. Let's stay tuned for it.
Sep 24, 2021 at 5:50 AM Post #3 of 3,151
Unlock the latest wireless experience. The #True Wireless Bluetooth Amplifier UTWS5# not only supports the TWS Mirroring mode with lower latency and better reliability, but also supports the smooth Snapdragon Sound. These flagship-grade audio technologies combine to support the newest aptX adaptive that allows a hi-res playback of up to 96kHz/24bit, making for clear phone calls and ultra-low latency game playing.
Sep 25, 2021 at 10:26 AM Post #4 of 3,151
Compared to the last generation, the #True Wireless Bluetooth Amplifier UTWS5# supports wireless charging for the first time. It is also the first product in the FiiO family that supports wireless charging. Other than ordinary wireless chargers on the market, we can use our mobile phone as a wireless charger. Just enable the reverse wireless charging function on the mobile phone and then put the charging case of the UTWS5 on the rear cover of the phone to enjoy wireless charging.
Sep 27, 2021 at 9:34 PM Post #5 of 3,151
FiiO's 2021 Autumn New Products Launch Event II will soon be starting!
In this beautiful autumn, we would like to share some more stories with you. Join us at this big party.
This time, we will have 3 participants- flagship true wireless Bluetooth amplifier UTWS5, high-purity pure silver swappable plug headphone cable LC-RD and gold-silver-copper braided swappable plug headphone cable LC-RE Pro. As successors of previous excellent products in the FiiO family, what are their improvements? Will there be any new and interesting functions? More surprises will be exposed later.
Tonight at 19:00 (BJT), live streaming with photos and words of the Launch Event will be carried on at the following social platforms- Head-fi, Facebook, Twitter and Reddit. See you then.
BTW, if you are interested in the live video of our Launch Event, you can also click the link to join us: https://live.bilibili.com/21313666 (Room NO. 21313666) (The Launch Event will be in Chinese and accessibility cannot be guaranteed.)
Sep 28, 2021 at 7:04 AM Post #7 of 3,151
FiiO has already started the research and development of Bluetooth HiFi products, and has rich product lines up till now. Other than Bluetooth DAC/Amps and the BTR series, we have manufactured Bluetooth cables, neckband sports Bluetooth cable, Bluetooth headphones, Bluetooth ear hooks and TWS earphones. They were all highly praised by consumers. However, the past is the past while the future matters more. Next, our #Flagship True Wireless Bluetooth Amplifier UTWS5# will lead us to a new road.
Sep 28, 2021 at 7:08 AM Post #8 of 3,151
To make Bluetooth earphones match to high-fidelity audio devices, efforts should be put on the audio structure. Therefore, the #Flagship True Wireless Bluetooth Amplifier UTWS5# is equipped with an independent DAC for the first time. Each of the left and right sides features an AK4332 DAC chip where the Bluetooth signals received from the source end will be decoded and amplified, thus achieving great improvement in performance.
Sep 28, 2021 at 7:10 AM Post #9 of 3,151
Apart from the DAC improvement, we have carefully selected Qualcomm's latest and most powerful Bluetooth QCC5141, which has many merits- supports Bluetooth 5.2, newest aptX adaptive, and Qualcomm Snapdragon sound technology, and can transmit 96kHz/24bit Hi-res audio!
Sep 28, 2021 at 7:12 AM Post #10 of 3,151
In terms of connection, the UTWS5 supports Qualcomm's third-gen TWS technology, i.e. the TWS Mirroring, which is considered the best transmission mode of TWS earphones. It can smartly make switches between primary and secondary channels yet with lower latency, and has almost no requirements for the transmitting end. Basically, all Android devices support the TWS Mirroring mode for connection.
Sep 28, 2021 at 7:13 AM Post #11 of 3,151
The UTWS5 supports wireless charging. At the bottom of the charging case, there is a wireless charging coil that is compatible with QI wireless charging protocol with about 2 hours for a full charge. The UTWS5 has a battery life of about 6.5 hours per charge, total battery life of 30 hours with the charging case good for 4-5 charges.
Sep 28, 2021 at 7:14 AM Post #12 of 3,151
To achieve an accurate volume adjustment, the UTWS5 is designed with more independent volume levels. From 26 levels of the UTWS3 to now 32 levels, we can precisely set the volume to where we want. It is good for high-sensitivity headphones, and it even supports Hi-res music experiences and phone calls.
Sep 28, 2021 at 7:17 AM Post #13 of 3,151
In terms of wearing, the UTWS5 takes an over-the-ear design the same as the UTWS3 to relieve pressure on the ears. In terms of connectors, the MMCX/0.78mm connectors help to turn your idle interchange cable earphones into TWS ones. The large cavity charging case accommodates a greater variety of earphones attached to the UTWS5. With simple taps on the large tactile button, you can quickly access the controls you want. Besides, with an IPX4 rating, we don't need to worry about the UTWS5 being damaged by water or sweat as you go about your life.
Sep 28, 2021 at 7:19 AM Post #14 of 3,151
In the end, let's make a review of the characteristics of the #Flagship True Wireless Bluetooth Amplifier UTWS5#-- the world's first independent AK4332 DAC, flagship Bluetooth QCC5141 chip, Bluetooth 5.2, third-gen TWS technology, aptX adaptive support, 96K/32bit Hi-res audio, wireless charging... How powerful will it be!
Sep 28, 2021 at 7:22 AM Post #15 of 3,151
The omnipotent and intelligent #Flagship True Wireless Bluetooth Amplifier UTWS5# only sells 119.99 USD (US market) and will be available on Amazon/AliExpress store and our worldwide sales agents expected in October. For more introductions and information, please follow us to check.
