According to the phenomenon you mentioned, it is more likely to be a hardware issue with the charging connector. You could contact the seller to see whether he could help first. If not, please contact us again via support@fiio.com. Sorry for bringing inconvenience to you.The connectors are considerably clean since it is not used often and there was a period of around 1 month that I left it unused, the issue did happen after updating to v.0.2.53, before updating, it didn't have that behavior... So unsure if it's a software issue or hardware one...
It seems to work sometimes when I wiggle the module in the case, but sometimes it would not even work so in the end, it does not charge
Thank you
Best regards
