Does anyone know if OnePlus 8t support tws+? How do I know if a phone supports tws+?
[FiiO UTWS3] True Wireless Bluetooth Module/MMCX/0.78 2pin/QCC3020/TPA6140A2/ Bluetooth 5.0
- Thread starter FiiO
Dear friend,Does anyone know if OnePlus 8t support tws+? How do I know if a phone supports tws+?
If your mobile phone supports TWS+, the UTWS3 in the Bluetooth page will shows like that:
If not, only the master ear hook will show with 'connected':
Best regards
Luke Skywalker
Well I just got my UTSW3s and hooked up my JH Audio Lolas and wow... incredible. Super comfortable and the sound is stunning.
Here is my only complaint... My IEMs don't fit in the case when connected. Like not even close... So I have to unhook them every time I want to listen and even then they barely fit in there. Wish the case was a lot bigger to accommodate a wider range of IEMs
Thanks for the feedback.Well I just got my UTSW3s and hooked up my JH Audio Lolas and wow... incredible. Super comfortable and the sound is stunning.
We will record about that.
Can adjusting the headphone unit in different direction or changing the eartips help?
Best regards
Luke Skywalker
Thanks for the reply... no, I need to disconnect my JH Lola‘s completely and they still barely fit.Thanks for the feedback.
Best regards
But wow, the sound is amazing. They’re far more comfortable and secure than any of my TWS buds. I love the controls too
davidcotton
X-CANs and HDAMs
- Jun 23, 2001
Any problems for glasses wearers? Also are these iOS compatible?
Dear friend,Any problems for glasses wearers? Also are these iOS compatible?
Glasses wearer could wear it without problem:
And it is compatible with iOS devices.
Best regards
potatohead
- Oct 5, 2012
would like to know too, also their parent company oppo; maybe @FiiO can comment as they probably have every brand of phone on hand to test out their productsDoes anyone know if OnePlus 8t support tws+? How do I know if a phone supports tws+?
Fiio replied and said I need to manually open Bluetooth and check. So I guess they don't knowwould like to know too, also their parent company oppo; maybe @FiiO can comment as they probably have every brand of phone on hand to test out their products![]()
BlazdiqFoods
Enable Developers Option on your android. And then, open Developers Option, under Bluetooth Audio Codec, you should be able to see it your device supports TWS+.Fiio replied and said I need to manually open Bluetooth and check. So I guess they don't know
I rmb seeing my friend's OnePlus6 and it supports TWS+
I don't actually have the phone yet. I was asking before purchasing the phone. I thought there was a way to find out what phones support TWS+
BlazdiqFoods
https://forum.xda-developers.com/t/aptx-adaptive-support.4184831/I don't actually have the phone yet. I was asking before purchasing the phone. I thought there was a way to find out what phones support TWS+
I guess they do have? Look at the photo attached at one of the replies
SilverZephyr
Hmmm, it seems that my UTWS3 R module is facing some problems, even after putting the R module back in the charging case, it does not turn off and disconnect from the phone. I have tried resetting the modules by holding down the button in the charging case until the light alternates between red and white. Any insights would be very helpful. Thank you
Dear friend,Hmmm, it seems that my UTWS3 R module is facing some problems, even after putting the R module back in the charging case, it does not turn off and disconnect from the phone. I have tried resetting the modules by holding down the button in the charging case until the light alternates between red and white. Any insights would be very helpful. Thank you
You could try to clean the connector for the UTWS3 to check whether the issue remains: https://forum.fiio.com/note/showNoteContent.do?id=202105211656085546722
Best regards
SilverZephyr
The connectors are considerably clean since it is not used often and there was a period of around 1 month that I left it unused, the issue did happen after updating to v.0.2.53, before updating, it didn't have that behavior... So unsure if it's a software issue or hardware one...Dear friend,
Best regards
It seems to work sometimes when I wiggle the module in the case, but sometimes it would not even work so in the end, it does not charge
Thank you
