Yeah, the regular M11 is like that too. I've yet to figure out how to use the internal memory and have to pull off the case, remove the SD cards with that special key, and copy everything to my cards this way. The internal memory is largely unused at this point and I wish I could use it for music I want to try out on a more frequent basis.Just Received my FIIO M11 Pro October 5. When I connect the player to the computer and attempt to transfer files from Windows Media Player, the drive reads the location as Linux and with only 32 Mb of storage, but the internal memory has about 59 Gb. I then attempted to install the MTP driver but I receive a message box warning that the action was blocked by the Administrator for security reasons. ?
FiiO releases Android-based Lossless Portable Music Player M11 Pro!
- Home
- Forums
- Head-Fi Special Forums
- Premier Sponsor Forums and Sponsor Forums
- FiiO
- Thread starter FiiO
- Tags
- fiio fiio m11 pro m11 m11 pro
Dear friend,Just Received my FIIO M11 Pro October 5. When I connect the player to the computer and attempt to transfer files from Windows Media Player, the drive reads the location as Linux and with only 32 Mb of storage, but the internal memory has about 59 Gb. I then attempted to install the MTP driver but I receive a message box warning that the action was blocked by the Administrator for security reasons. ?
Is your computer a Window 10?
This warning?
If yes, you may try this method:
Best regards
- Nov 29, 2013
Wont buy until I can get a case!
Mine is coming Friday and am a little paniced about a case to protect it. Do we know if the case for the M11 (non - Pro) will fit?
It does. There are also aftermarket cases.
moonblink71
- Apr 12, 2016
Hello head-fiers! I just purchased a case for the M11 pro but the seller mentioned that the m11 case won’t fit. Unfortunately I don’t have the M11 to compare. Does anyone have the dimensions between the two. By just looking the physical specs seem the same.
- Nov 29, 2013
Keep us updated on what you find... does the M11 case actually fit the M11 Pro.
Initial impressions of this Fiio is an extremely detailed and lively presentation.
I put mine back in the box until I get my case tomorrow, ordered here:
Just a stock m11 case. I didn't see any for a pro.
I also have another unit in pic not the fiio.
Single-ended output was very strong and I will be checking out balanced output later.
To the users: How fluid is this device? I returned my iBasso DX220 mostly due to laggy UI.
It operated nice and fluid to me..
This unit sounds different over the ibasso. It is very vivid and detailed in the upper-mids to trebles , (almost euphoric in its liveliness), so I would say it a bit more more lively over the ibasso, yet the ibasso with amp8 has the edge on power with a slight more distanced presentation.
Personally, I think the Fiio unit would match up wonderfully with both laid-back and slightly thicker headphones.
Extremely engaging sound overall..
My main unit currently is the Sony WM1a, and I feel the fiio is a worthy lower cost alternative ( although different sounding).
It definitely punches higher in sound than I expected.
I am hoping that break in period will help it get better.
Dear friend,Hello head-fiers! I just purchased a case for the M11 pro but the seller mentioned that the m11 case won’t fit. Unfortunately I don’t have the M11 to compare. Does anyone have the dimensions between the two. By just looking the physical specs seem the same.
The M11PRO is 1mm thicker than the M11. So the M11's clear case is not suitable for M11PRO.
Best regards
JamesPTao
Does this player have true direct dsd decoding or dsd via flak conversion?
Building on the foundations of the M11, the M11 Pro has been updated to include:
1. Two carefully implemented AK4497EQ DAC chips based on the AKM VELVET AUDIO architecture. Compared to the AK4493EQ, the AK4497EQ brings better specifications and noticeable improved sound quality.
2. Dual THX AAA-78 amplifier module in a balanced configuration, the sound quality just gets even more amazing.
3. Dual independent crystal oscillators in an all-new upgraded clock system.
Key features of the FiiOM11 Proinclude:
To find out more about the M11 Pro, please visit the product page on https://fiio.com/m11pro.
- Powerful Samsung Exynos 7872 processor
- Audiophile-grade 2x AK4497EQ DACs
- THX AAA-78 amplifiers in fully balanced configuration
- Dual independent crystal oscillators in an upgraded clock system
- Full-format Bluetooth transmission + LDAC lossless Bluetooth reception support
- 2.5mm/3.5mm/4.4mm headphone outputs
- Symmetrical USB Type-C connector with decoding and output functions
- AirPlay/DLNA/WiFi convenient wireless transmission
- Bluetooth/single-ended/balanced/line out/USB/coaxial output methods
- 3GB RAM + 64GB built-in storage + up to 2TB expandable storage
- 5.15 inch 18:9720P touchscreen
- Supports both QC2.0+MTK PEfast charging
- 9.5hours battery life, 55 days deep sleep standby time
- Global All To DSD functionality
- Open-source Android OS
- Dual Hi-Res Audio certifications
- Available in Black
Shipments of M11 Pro to respective distributors begins at 25thSeptember and will provide updates via our webpage at https://fiio.com/newsinfo/314104.html, If you are interested in getting one, check with our respective local sales agent (at https://bit.ly/2OBzJpn) for its availability or grab one from FiiO Aliexpress store at: https://www.aliexpress.com/item/4000199934716.html
Note: M11Pro will be released globally at the same day, but somecountries need may delayed due to certification requirements. For more details, please contact our local distributor before purchasing.
Best Regards
FiiO Electronics Technology Co., Ltd
Dear friend,Does this player have true direct dsd decoding or dsd via flak conversion?
When using FiiO Music app, there is no SRC.
Best regards
I'd like to hear your impressions of the differences between the Fiio M11 pro and the Sony WM1A.
I ask you this because I expect a good price of used for Sony.
Thanks
- Home
- Forums
- FiiO
