- Jul 30, 2015
uses x7 amp modules so power a matter of choice or default amp supplied.
Good thing, that's my preference! Medium power, balanced out, right?
DAC:AK4490EN×2Not sure if we are talking about the same pic/diagram, but didn't it just show the dual DACs?
There are two USB interfaces. You don't have to connect all to use it,Two USB ports, one for data and other for charging. Does that mean if I'm connecting to a PC then I would HAVE to use 2 usb cables if I'm planning on keeping it running for more than the battery-life allows?
If so, that would be quite an inconvenience...
Price: 349.99USDPrice?
Power output?
If it sounds anything like the x5iii thats not a good thing. For me anyways.
Bottom amp module interface: 3.5 PO, micro USB, 2.5BAL.Good thing, that's my preference! Medium power, balanced out, right?
DAC:AK4490EN×2
What is the output impedence of the balanced out?
Just make your own adapter.It's too bad there isn't a balanced line out.
You take the balanced out from the 2.5 mm TRRS and add a pair of XLR's. It's not hard to do.An adapter isn't going to make a single ended line out provide a balanced signal
