obsidyen
I'm an iPhone and MacBook Pro user so I'm glad that you're making Q5 compatible to Apple products.
Q5 design, consider a wide range of use.
To meet the best sound quality, USB in, Spdif in.
To meet the best use of convenience, Bluetooth in and regular jack out to headphone.
Bass adjusting features, the Q series products will be used to achieve all the way to a simple switch, including the upcoming Q1Mark Ⅱ. I am sorry E17K to bring you the use of trouble.Fiio, it looks like you are dropping the treble and bass adjusting features of the e7k and e17/17k, and instead using a simple bass boost switch. Is this true? If so, are you also planning this for the upcoming q3? Will you be offering any dac/amps in the future that will have treble and bass adjusting features like the e17/17k? In my opinion, this feature is what has separated your dac/amps from the competition, and has been what keeps me coming back to them.
1. Decoding with iPhone normal, computer USB DAC play DSD normal.
2. Line input is normal.
3. Coaxial input with X7 Ⅱ, normal use
4. Optical input, the first time access problems, reset once. Support to 96K, the use of X7 Ⅱ fiber output source
5. VOL Knob feel OK, it can be placed on the desktop with your fingers.
6. Bluetooth connection phone, open and close easy to remember, connect the phone need to wait for red and blue light flash. and pair.
7. Bluetooth connection iPhone, control music keys normal, can not answer calls, you can listen to WeChat.
8. Lamp light effect is good.
9. With K5 use, K5 must power-on to charge Q5, decoding normal.
