FiiO Mont Blanc/E12 portable headphone amp, 880mW, slim design, full metal case. Bass boost and Cross feed!
Mar 22, 2014 at 11:33 PM Post #2,761 of 3,739
Hey what does the red color?
It looks red!
Is that why they call it red?
Mar 23, 2014 at 2:56 PM Post #2,762 of 3,739
Mar 23, 2014 at 3:56 PM Post #2,764 of 3,739
Mar 31, 2014 at 5:52 PM Post #2,766 of 3,739
Hi first post here! I think my Fiio e12 volume is not working the amp is not very loud at max volume 0 gain, about as loud as an ipod or zune. From what I've been reading It should be plenty loud at 11o'clock - 12o'clock. I'm using martin logan m90 (26 Ohms)
Mar 31, 2014 at 10:16 PM Post #2,772 of 3,739
Have you checked the gain switch?
Helpful info, please, guys! Thoroughly read his posts before jumping the gun. He should not have to put it on high gain for the Mikros M90s!
  I guess I just need To know if playing this amp at max volume is normal or not. If it is not working properly I'll return it
Get a replacement, my friend. Something isn't right if you say your source is at max volume, and the E12 is at max volume with the Mikros....
Mar 31, 2014 at 11:07 PM Post #2,773 of 3,739
In his post he said it was set for 0 gain (line level). It's POSSIBLE the switch could be stuck inbetween or something, but FWIR when that happens you get BOTH line level and high gain circuits going, so it still shouldn't be too quiet.
I don't know what sensitivity the Martin Logan M90 rates, in fact I don't know much about the ML M90s at all (ML makes headphones too?), but my E12 can drive everything from my EarPods to my K712 Pros to deafening levels (literally). That said, my 5th gen iPod can drive my 50 Ohm Koss KSC75s louder than I'm comfortable listening to.
Mar 31, 2014 at 11:57 PM Post #2,774 of 3,739
Thanks for the fast reply. I should of stated that the source volume is at max. Everything sounds great. I thought it was going to be louder. I think the volume nob might not be working right
Everything means other phones from your collection? Did you/do yiu hear any static while turning the pot/knob? Do you hear the difference when you use gain,BB CF switches though low volume? Did you notice this issue all of a sudden while active listening or the other way? Hope you didnt drop it facing volume knob hittin the floor?:wink:
finally, hows the charging and discharging status of the Amp,normal?
Apr 1, 2014 at 12:10 AM Post #2,775 of 3,739
To add,check the volume limit under Settings as well. Just............somebody would've tweaked accidentally,w/o your knowledge.
