Sorry. I just seen that’s a 3.5 to 2.5 adapter. It’s reverse from what I thought although you can still get a 2.5 to 3.5 but I suspect it would short out the amp output
Is there any way to take screenshots on this device? Also, how can I get songs to show up in the Recently Added section within the Fiio app?
Is there a specific folder that the music needs to be placed in? I see some of my songs showing up there but not others. I use an external memory card with two different sub folders within it to store my music.
Hello. I have tried a few different scenarios for sleep mode. If i set the sleep setting for “x” amount of minutes it seems like it powers on after I come back to it as a regular boot. If I turn off sleep and amd automatic power off it just turns the screen off and saves position in song.
Is that what fiio means about the 40 day life sitting on that screen at the same position or having it power right down till next time?
Is there a difference between sleep and power off?
Also, if I wanted to utilize the power bump from the balanced connector without buying a balanced cable set would the fiio brand 2.5 trrs to 3.5 adapter provide that power boost?
I would be aware that it won’t be a fully balanced setup though as intended but it may be a way to squeeze a bit more juice out with higher impedance headphones without changing the sound quality over the 3.5 output ?
Does that logic sound correct?
Thanks in advance.
After a complete charge, the battery went down to 25% without using it much.
Now my FiiO M9 is charging, 25% to 31% within 2 - 3 minutes! It seems like the battery increases every 1% so fast even less than 40 seconds.
I am using the included cable with a 5V 2A charger as recommended. From 28%, it shows the estimated charging time as 37 minutes. (photos taken if you want to see.)
Is this fine?
Edit: It takes 1 minute or longer per 1% charge when the battery is 80%+
Considering the limited ability to 'upload' or get those files off past moving it to SD storage and transfering it manually.... I typically would just resort to using a smartphone to take itIs there any way to take screenshots on this device? Also, how can I get songs to show up in the Recently Added section within the Fiio app?
Can folks please test left right balance
It wasn't operational when I tried it.
Apologies for the silly question but....
I’m considering buying this for both FLAC files and Spotify.
Everyone is mentioning streaming with Spotify and I note that I’ll be able to load Spotify onto the M9.
My question is ‘will this device allow me to download Spotify playlists / albums onto the MicroSD card for offline listening?’ I subscribe to Spotify and currently use an aging iPod Classic for the music I own and use an iPhone for offline Spotify listening. If the M9 will indeed allow me to download Spotify files then I think it’s a good solution for me but, if it’s streaming only, there’s not much point for my purposes.
That's quite a long couple paragraphs for a short question haha.
Yes you can. I haven't found how you can tell it WHERE to download to (either internal or SD) but it will do so yes.
