- Jan 30, 2011
Just to check is this considered better than fiio x5iii?
I'll probably buck the trend here a bit. Sound-wise most DAPs are equivalent - slight changes in tonality - but most nowadays have equivalent distortion levels, crosstalk levels, SNR levels etc, and anything that matters is below the level of audibility.
From a GUI perspective the M9 is a lot more fluid, and a little more stable - but its also locked down quite a bit more (less you can do with it)
The things I'd miss from the X5iii are:
- Viper (I use it all the time)
- Access to any app I want (within reason). Eg - I often use Neutron
- Tonality. Yes the X5iii is a warm DAP. Its also really nice to listen to.
I have access to DAPs ranging right up to 1K plus - the one I still tend to use the most is the X5iii. Its not perfect. I'm going to have a crack at installing a custom kernel and see if that speeds things up a bit.
With every DAP there are compromises. Thats why there is no best. We all have different triggers. The best is what suits your individual preferences best.
