FiiO M9 , Android based Hi-Res smart DAP with 3.5/2.5 powerful output|AKM4490 X2 |WiFi|aptX/aptX HD/LDAC/HWA(LHDC)|USB DAC|USB AUDIO OUT
Discussion in 'Portable Source Gear' started by JamesFiiO, Aug 10, 2018.
30 31 32 33 34 35 36 37 38 39
41 42 43 44 45 46 47 48 49 50
  1. Dobrescu George
  2. steelgtr
  3. Dobrescu George
    You can use the 3.5mm SE output with that cable alone, and set it to Line out :)
    You'd be solving a lot of headache, because that cable is not balanced either...
    If you mean cutting it, you can cut the short terminator above, since it has a 4-pole 2.5mm male jack, and connect the 2 X RCA cables to that, but you need to be really careful to not connect the negative and positive the wrong way
    Unfortunately, if you'd want to keep the connectors balanced, you'd have to cut the RCA cables after their split, otherwise the ground is connected between the left and the right channel............
    Quite a bit of work, I'd stick with using the 3.5mm SE output of M9 :)
  4. bakanecko
    Hey how do you compare this with Q1mii for both SE and balanced output, i really like the sound of Q1 m2 balanced output but not the SE. I even like it better than Q5 with its default amp module, somehow i feel the stock amp of Q5 sound a bit to thin for my taste. I mainly use akg n40 and campfire audio comet, and sony nba3 (all of these v-shape or u-shape) with balanced output these days.
  5. FiiO
    Dear friend,
    The M9 could enter stand-by mode when it is not playing music with Wifi and Bluetooth. You don't need to turn it on.
    Best regards
    FiiO Stay updated on FiiO at their sponsor page on Head-Fi.
    https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com http://fiio.udesk.cn/im_client/?web_plugin_id=24494&group_id=47899&language=en-us
  6. FiiO
    Dear friend,
    Did you try another APP as well? Only the Tidal APP has the problem? Or please try to do a factory restore to see if it helps?
    Best regards
  7. battosai
    We were talking about the Fiio logo not showing up on Tidal, I don't know if it is normal or not but it doesn't matter. What matters is that the screen of my M9 doesn't show the gray color in any app 95% of the time. That's why it is so bizarre... And that's why I am returning the unit. Factory reset didn't help.
  8. FiiO
    FiiO releases the new firmware FW1.0.2 for M9
    Added some more 3rd-party apps to white list, including JOOX, ES file manager, Bandcamp, and Sony headphones;
    Note: You can copy the apk file of the qualified app to the M9’s internal memory or external Micro SD card, then open the File Management app, locate and click on the apk file to install it.
    >>> More information
    [​IMG]
  9. Sven2015
    @FiiO
    Hey, I can see the Sony app "sony headphones" as 3rd party app? Thanks for supporting this app now. I don't own the M9, but I'm interested in... :)
  10. Sylean
    Thanks,
    I can see two items in the options regarding this, should I let them to "off" ?
  11. dharmasteve
    Anyone out there managed to set up the M9 to stream to a HiFi system through WiFi? Through Bluetooth it's quite simple. I stream to a Bluetooth receiver which has an optical cable to a DAC to a mini amp to my speakers. It's Aptx and sounds good. When I replace the Bluetooth receiver with a Ezcast M7 WiFi receiver, I get nothing whether I connect to my own WiFi or directly to the Ezcast. The Fiio app's DLNA just finds my Laptop. My Samsung phone, my iPad Mini, and my Amazon Fire tablet all can find the Ezcast box no problem, and I can listen to my music library on my HFi. Essentially I am still using my mobile phone if I want to listen to music through WiFi on my HiFi. I am receiving an Aptx hd receiver later this week so I will use Bluetooth, but I would rather use Wifi. It seems it's not possible to stream to WiFi out of the M9. Has anyone managed to do this? The problem would be very easily solved by having a music casting app on the M9 but Fiio have not got one whitelisted, even on the new firmware, strange to say the least. Unfortunately it seems the M9 cannot stream out through WiFi at the moment. Such a simple issue to resolve. Very poor. In other usage with IEMs or Bluetooth I do love this little player. Very sophisticated sound through my Tin Audio T2s and T2 pros. It is a very musically refined but exciting sounding player and I do not want to sell it. But please Fiio, I know you read these posts so please solve the problem. To me it's a major problem. I would like to play my music library from my M9 on my HiFi system using WiFi. It's not a big complicated thing to do and would put you ahead of the other DAP makers.
  12. JuanLuis91
    Do not have plans to support soundcloud?
  13. Detectit
    Very nice..... More apps to the list....
    But what do you do with the suggestions mentioned here??
    Another third party player with more dedicated NAS features?
    And TuneIn?
    Investigating ?? Trying ?? Or is it a no go?
    Sinarca likes this.
  14. Detectit
    Okay... I guess i never looked further in Es file explorer than the file management.
    But Es file Explorer is more than a file manager it's a. Media Player, browser.. . Etc etc.
    We can even acces the web on ES explorer.. And yes we even can watch Youtube.... OK the last isn't the smoothest of course. But hey it's possible.... IMAG2660.jpg
    trellus likes this.
  15. doowap
    I actually haven't had the chance to test the balanced output as I do not have balanced cables for any of my headphones yet, so I don't think I can help you. I can say though, I have a campfire comet and I love using it with the SE output on the Q1mkii, so perhaps our tastes differ.
