dharmasteve
I don’t totally agree. The M9 is very much designed for portable use,with the Fiio music app. Used this way it does everything it should,and does it superbly. The CPU is perfectly adequate for this. However,I speak as someone who doesn’t stream and primarily use the M9 for its excellent Bluetooth. I love it,and I do have the M11 too. They are designed for different needs and I think they are both excellent. I would say that it’s well overdue a firmware update and this is regrettable,Fiio need to look after all their customers and the M9 is still a new device. Makes me wonder if they will abandon the M11 when the new daps scheduled for this year appear. They are meant to be high end and I can assure you firmwear updates for the x7ii appear to be nothing but a memory.
I think you are right. Streaming Spotify, wireless, balanced output, LDAC, APTX-HD, and playing local files all really work well and sound excellent. OK like most big companies FiiO will let you down in terms of support but the hardware and basic software is good. Support is the usual couldn't give a ****. That's always the problem. At the moment they are only supporting the FiiO M11.
