FiiO M9 , Android based Hi-Res smart DAP with 3.5/2.5 powerful output|AKM4490 X2 |WiFi|aptX/aptX HD/LDAC/HWA(LHDC)|USB DAC|USB AUDIO OUT
post-14532924
Post #181 of 2,395
stenog
Denmark
Denmark
Headphone out specifications 1(3.5mm port)
Output power 1 ≥125mW(16Ω / THD+N<1%) Output impedance <2Ω
Output power 2 ≥170mW(32Ω /THD+N<1%) THD+N <0.002%(1kHz/32Ω)
Output power 3 ≥19mW(300Ω / THD+N<1%) Separation >72dB
Frequency response 5Hz~80 kHz(-3dB) Peak output voltage 6.5Vp-p
SNR ≥118dB (A-weighted) Noise floor <5uV
Headphone out specifications 2(2.5mm port)
Output power 2 ≥195mW(32Ω /THD+N<1%,balanced turbo off)
≥220mW(32Ω /THD+N<1%,balanced turbo on) THD+N <0.002%(1kHz/32Ω)
Output power 3 ≥24mW(300Ω / THD+N<1%,balanced turbo off)
≥77mW(300Ω / THD+N<1%,balanced turbo on) Separation >98dB
Frequency response 5Hz~80 kHz(-3dB) Peak output voltage 7.07Vp-p
SNR ≥113dB (A-weighted) Noise floor <10uV
If these numbers are correct then power output is more than ok!
Here are the specs for X7II.
http://m.fiio.net/en/products/71/parameters
post-14532952
Post #182 of 2,395
Tsukuyomi
Canada
Canada
it seems quite low to me, my FiiO X5III pushes more power than M9.
post-14532964
Post #183 of 2,395
stenog
Denmark
Denmark
What do you need all this power for? If you intend to drive 600 ohm headphones, a "normal" dap is probably not the right device. I can drive both Beyer Amiron and Aeon Open with the X7II in SE and I don't get past 80/120. Not saying that this is the best combination, but it's possible.
M9
Output power 2 ≥170mW(32Ω)
X7II
Output power 2 ≥150 mW(32Ω)
Reactions: trellus
post-14533312
Post #184 of 2,395
Tsukuyomi
Canada
Canada
I'm going to be using the dap mostly for my B&O H6 when outside (they dont require much power so i know they're not the focus here.) what im gonna be using them more for is my DT1990 Pro's and Audeze LCD2C and potentially AKG K712Pro and possibly my friends Hifiman Sundara.
I'm looking at the new Cayin N5iiS and maybe the A&K AK70 MK II, A&norma SR15,or the AK100II.
its hard to find a DAP that can push all thoes headphones mentioned above (minus the B&O H6II) without going over 800$CND.. by a lot..
post-14533366
Post #185 of 2,395
superuser1
Sapta Sindhu
Sapta Sindhu
I believe the DX150 can do all those with different amps of course!
Reactions: stenog
post-14534669
Post #186 of 2,395
Tsukuyomi
Canada
Canada
I dont want to have to amp swap :p i'd rather have one solid unit.
Reactions: superuser1
post-14534679
Post #187 of 2,395
FiiO
Sponsor: FiiO
Guangzhou,China
Guangzhou,China
Age
13
Website
www.fiio.com
3. FiiO M9 Hi-Res Audio Player丨The Ultimate in Versatility
Inside the M9 is a high-performing A3P030 FPGA, ensuring your music is played back accurately by stabilizing digital clock signals. The FPGA also decodes DSD64/128 in hardware, which the M9 supports in ISO/DFF/DSF formats.
https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com
Reactions: trellus
post-14536005
Post #188 of 2,395
thrgk
Do you know when it will be available in the US and what sellers ?
Looks like a great player
post-14536843
Post #190 of 2,395
thrgk
Yeah hopefully Amazon has it in the US like Amazon in the UK does on10/19 :)
I am also curious about a US release date.
post-14540516
Post #191 of 2,395
Tsukuyomi
Canada
Canada
M9
X7II
Do you know if the M9 can run/drive Hifiman Sundara, AKG K712 Pro, BeyerDynamic DT1990 Pro, Audeze LCD2C(classic) and Fostex th-900 mk2??
if it can, sold! lol i'll buy it asap.
post-14540725
Post #192 of 2,395
stephanemtl
Based on the specs, the M9 looks fantastic: small, affordable, and capable of Tidal offline playing.
That being said, my experience with the X7, 1st gen, has taught me to be extremely cautious about initial claims made by Fiio, claims that are never realized even after two years of updates.
I hope the M9 will truly have (1) a reliable wifi, (2) an absence of audible wifi interference/noise when using Tidal online and (3) an absence of stuttering songs when using Tidal offline.
Reactions: trellus
post-14541403
Post #193 of 2,395
FiiO
Sponsor: FiiO
Guangzhou,China
Guangzhou,China
Age
13
Website
www.fiio.com
4. FiiO M9 Portable High-Resolution Audio Player丨The Ultimate in Versatility
The M9 uses Bluetooth 4.2 and supports all Bluetooth formats including the hi-res ones for your ultimate listening pleasure, including: 24bit aptX HD (also backwards compatible with aptX), LDAC, and HWA.
Reactions: trellus
post-14541504
Post #194 of 2,395
seanwee
It will drive the Sundara fine. Even the N5ii manages with its 150mw/32ohm output.
post-14543762
Post #195 of 2,395
FiiO
Sponsor: FiiO
Guangzhou,China
Guangzhou,China
Age
13
Website
www.fiio.com
5. FiiO M9 Hi-Res Audio Player丨The Ultimate in Versatility
The M9 contains both single-ended 3.5mm and balanced 2.5mm audio jacks. The M9 also supports in-line controls in both CTIA (common with Android headsets) and iOS headsets. (With iOS headsets, only play/pause is supported.)
Reactions: trellus
