FiiO M9 , Android based Hi-Res smart DAP with 3.5/2.5 powerful output|AKM4490 X2 |WiFi|aptX/aptX HD/LDAC/HWA(LHDC)|USB DAC|USB AUDIO OUT
post-14527538
Post #166 of 2,395
kgs51
In USD how much will the FiiO M9 cost and when will it be available in US. Thanks
post-14527560
Post #167 of 2,395
Soham Sengupta
Kolkata, India
Kolkata, India
post-14527641
Post #168 of 2,395
davidcotton
X-CANs and HDAMs
post-14528441
Post #169 of 2,395
Sven2015
What is the difference between M7 and M9?
I own a M7, but several things are not good (bad display, crashes, a simple music app with less functions, simple EQ)...
@FiiO
Please tell me the difference between the M7 and M9. Thanks
post-14530052
Post #170 of 2,395
Music Enthusiast
UK
UK
If you really want Bluetooth then get the M9.
Sound wise I do find the DX120 to be a tier up. Its a sound chameleon actually. Aside from 5 digital filters it also has 5 sound modes that can change it from neutral to warm sounding. If I were to go for the DX120 it would mainly be for the superior bass extension.
Either way both would be much better than the X1.
Hi Seanwee. As the Fiio M9 appears to uses the same DACs as the Shanling M3S - I'm curious if you happen to have heard the Shanling M3S and, if so, how it compares sound quality wise?
post-14530330
Post #171 of 2,395
seanwee
It's been a while since I heard the M3S but I do believe that the M9 is better.
The M3S is coloured while the M9 is more neutral. The M3S should also be darker sounding if I'm not mistaken.
post-14530655
Post #172 of 2,395
FiiO
Sponsor: FiiO
Guangzhou,China
Guangzhou,China
Age
13
Website
www.fiio.com
1. FiiO M9 Portable High-Resolution Audio Player丨The Ultimate in Versatility
The two AK4490EN DACs employed in the M9 feature a high signal-to-noise ratio, exceptional dynamic range, and low distortion – making for a precise yet exciting sound signature.
https://www.facebook.com/FiiOAUDIO https://twitter.com/FiiO_official https://www.instagram.com/fiioofficial/ https://www.fiio.com
post-14530657
Post #173 of 2,395
seanwee
It actually looks even better in real life :)
post-14530693
Post #174 of 2,395
crabdog
Thailand
Thailand
Website
primeaudio.org
That is one beautiful device.:yum:
post-14531159
Post #175 of 2,395
Tsukuyomi
Canada
Canada
Its physically very attractive for a DAP, however the specs are less than desired. the power output for both 3.5 and 2.5 are very weak. even my X5 III has more output power than the M9... :frowning2: sad, seems i wont be picking this DAP up after all.
post-14531183
Post #176 of 2,395
stenog
Denmark
Denmark
I am not sure it's fair to look at it that way. The X5 has a lot of power for it's small size, if I don't remember wrong it has more power in SE than the X7II. But power output is not all :).
And i would assume that the M9 is made for iems and easy to drive headphones on the go. And most importantly how is the sound quality? :)
post-14531283
Post #177 of 2,395
seanwee
If you want lots of driving power you may want to consider the Opus 1S.
post-14532176
Post #178 of 2,395
Oncisounds
England
England
What's the power out of the new Fiio M9 are talking able to drive 150ohm headphones or more like 32ohm? I was looking at comparing this to the Pioneer XDP-300R and which was the better choice?
post-14532894
Post #179 of 2,395
FiiO
Sponsor: FiiO
Guangzhou,China
Guangzhou,China
Age
13
Website
www.fiio.com
2. FiiO M9 Portable High-Resolution Audio Player丨The Ultimate in Versatility
The TI OPA1612 is used as the LPF, while the TI OPA1622 serves as the BUF. To achieve single-ended and balanced output, there are 2 OPA1622 op-amps used that provide up to 77mW of power @ 300Ω load.
Reactions: trellus
post-14532897
Post #180 of 2,395
Tsukuyomi
Canada
Canada
Headphone out specifications 1(3.5mm port)
Output power 1 ≥125mW(16Ω / THD+N<1%) Output impedance <2Ω
Output power 2 ≥170mW(32Ω /THD+N<1%) THD+N <0.002%(1kHz/32Ω)
Output power 3 ≥19mW(300Ω / THD+N<1%) Separation >72dB
Frequency response 5Hz~80 kHz(-3dB) Peak output voltage 6.5Vp-p
SNR ≥118dB (A-weighted) Noise floor <5uV
Headphone out specifications 2(2.5mm port)
Output power 2 ≥195mW(32Ω /THD+N<1%,balanced turbo off)
≥220mW(32Ω /THD+N<1%,balanced turbo on) THD+N <0.002%(1kHz/32Ω)
Output power 3 ≥24mW(300Ω / THD+N<1%,balanced turbo off)
≥77mW(300Ω / THD+N<1%,balanced turbo on) Separation >98dB
Frequency response 5Hz~80 kHz(-3dB) Peak output voltage 7.07Vp-p
SNR ≥113dB (A-weighted) Noise floor <10uV
Reactions: trellus and stenog
