parawizard
Dear friend,
Were you trying to located the folder instead of the music file in the 'browse files' page? The quick search function could only work for the file name of the music instead of the folder. So you could not locate the folder via this function.
Best regards
You are saying it only works for files within folders? Why wouldn't it quick search through whatever the list is populated with on the current screen? It shows the quick search when there are folders but it doesn't work properly. I have my music well organized Artist/Album/Tracks and the library is very large at 80GB. They media library takes a very long time to update so browse folder works better sometimes on this device. If only the quick search worked properly.
