fourrobert13
Its because im going to buy it or e10.
Ok, but what is your question about them? The FiiO EX1 is the same iem, but recabled and cheaper. They have a v shape sound. I know nothing about the e10.
That's a neat little DAP!
It does have limitations and hopefully some things will get a patch to fix in the next firmware upgrade. It loves my purchased AAC files, I can live with that for now and I like the SQ of the M3. Hope it grows on you 4Rob13
Size does matterLOL
You are right, 40$ chaper.
Can you say me if it has good bass and if you recommend it to me?.
Thanks
I've been using the M3 at work today. I tried my PX100-II and did not care for the combination. First song i attempted to play popped up an error message that the format wasn't supported (320 mp3) so it skipped to the next song. I skipped back and it played the song this time. I've found no way to turn off playing through folders other than a repeat option, but it just repeats the album again so this is annoying to me. My Sansa's do not do this. The UI leaves little to be desired. My Sansa's have a decent UI and are cheaper so i'm not sure why FiiO can't use a dumbed down version of the X series players with the M3. The instructions are vague offer nothing other than initial start up info. The earbuds that came with won't stay in my ears which is very annoying as well. Keep in mind, i wasn't expecting greatness with this player, but so far i'm not really impressed. I'm going to give it a few more days, but if nothing changes i'm going to return it.
Give it a chance - you've had it for what - 2 days? Once I got used to the UI's quirks, they don't seem quite so annoying (to me anyway - YMMV). On your comparison with other Fiios and Clip - remember the others are all reasonably mature UIs, and most people I know have Rockboxed their Clips - again because the original UI wasn't the best.
The reason Fiio can't use the X series UI is simply because of the SOC limitations. This had to be built from scratch - hence the small irritations. I could name you a dozen errors so far - and things that should be fixed. I'm willing to bet over time that most of them will be. That's my experience with Fiio over a number of years. For $55, and considering the portability, build and sonics - I'd be willing to take that chance.
I love the portability of the M3 with my Adel U6.
I'm giving it a few days, but seriously the UI should be better than this regardless of the internals FiiO used. The file error occurs every time when i turn it on and they're files i purchased. If it ran on batteries, had replay gain, and gapless playback, it would be perfect. Honestly, FiiO's got something here, but not in its current state IMO. These quirks might be addressed in future fw and they may not due to the limitations of the chipset/RAM or whatever. I've figured out how to navigate the UI, but i still don't care for it. I like to play an album and then it stop when finished. The M3 just keeps on going which I don't want. Like we've told others in this discussion, this device doesn't fit my needs, so i'll stick to or find what does.
