newworld666
I am a bit hopeless, as I couldn't connect the M17 in DAC mode or file transfer with the box USB cable to any of my computers (4 tested) or smartphone (Z Fold3)...
I downloaded the drivers for windows as indicated in the manual .. but nothing happens when I plug the USB-C port.
I can use the same Fiio USB-Cable with A&K Kann Alpha (DAC mode or file transfer).
I can connect a SSD or Micro SD reader to this USB-C port and the M17 allows me to use it, but not a PC or Smartphone. I never had such issue with other FIIO DAP (M9 & M11).
I tried some other USB-C cables which works fine with other dap ..but not with M17
I tried a new beta Fiio USC drivers FiiO_v5.22.0_Beta.zip with no success.
I have never seen such issue, I will try to contact support@fiio.com and hoping they can fix something.
Am I the only one not to be able to use the M17 as a DAC with android 11 smartphones or windows 10/11 PC ?
Edit : It's impossible to join support@fiio.com as my mail is rejected ..
