riverground
Must’ve been quite a hard decision to make.Not, in fact, we plan to remove the optical out from m17 because we can't figure out how to protect the optical connector.
...instead of the opt out you can implement a network plug RJ45
Optical is useful, a rubber cover will doNot, in fact, we plan to remove the optical out from m17 because we can't figure out how to protect the optical connector.
If you hear 5 Hz frequencies you might want to let some scientists perform some tests on you.I hope it will goes low as 5 Hz in balanced. The subbass of m11 pro is very good. I can feel the earthquake not only earing it.
I have dap that goes 20 Hz down and I miss something in the very low end. It's between earing and feeling. M11 pro can reveal this very low end a little more and it's give music a special epic feeling. I don't know.If you hear 5 Hz frequencies you might want to let some scientists perform some tests on you.
You might be one of the lucky ones to hear below 20Hz, there are documented examples of people hearing down to 15Hz, but it's extremely rare. There is no evolutionary need to hear those frequencies.I have dap that goes 20 Hz down and I miss something in the very low end. It's between earing and feeling. M11 pro can reveal this very low end a little more and it's give music a special epic feeling. I don't know.
You can easily analyse the file and see what is the lowest frequencies present in the song. A 5 string double bass or 5 string electric guitar go down to 30Hz. That's the open, thickest string.Thanks everybody for your explanation. It helps me to better understand. But I don't know why, but on m11 pro, I feel sometimes a heavy breath on some very low tracks. I use two IEM that goes to 5Hz fiio fh7 and imr semper. And I miss it on my gears. I plan to replace my daps with fiio m17. I love what fiio makes. I appreciate your comments, thanks.
You could implement the optical out in the 3.5mm out. Just like the Kann Cube and my Panasonic TV.Not, in fact, we plan to remove the optical out from m17 because we can't figure out how to protect the optical connector.
Thank you for your reply!Not, in fact, we plan to remove the optical out from m17 because we can't figure out how to protect the optical connector.
I cannot open your link.Theoretically speaking, 5Hz will bring you hallucinations . You may see your great grand parents who voted as well. Here is an article, but I don’t think there is any LPF (Low Pass Filters) that would allow it. Though the M11Pro do have it listed out (frequencies responds and not LPF spectrums) 5-85Khz.....given that they listed an actual number, anything higher than 25Khz will burst your blood vessels and...melt your brain
http://www.bipcons.ce.tuiasi.ro/Archive/605.pdf
If M17 won't have optical-input, can you please make USB DAC mode compatible with current game consoles? I only wanted optical input because bluetooth is not good for gaming (too much latency even with fastest codecs), and M15 USB DAC mode is not compatible with PS4 unfortunately, so I cannot use it for gaming. If you guys could make M17 USB mode compatible with PS4-PS5, that would be an instant buy from me. (I think game console compatibility would also look good on product brochure and would increase sales, gaming consoles are a big thing nowadays).
Hopefully they will put a full SD in there, SDXC. Is plenty of space.
Don't know why I didn't see that microSD symbol before.
Thanks even though it's a bit disappointing considering storage requirements.
