I don't like pot at all whatsoever, but I do like music and trust my ears.Better pot? Lol.
[FiiO M17] Dual ES9038PRO, dual THXAAA-788+, dual power supplies, 9200mAh battery, 2 volume control modes
MusicalDoc8
Anyone tried using neutron player PCM to DSD 256 with the m17? can you give feedback on how much it heats up on balanced connection?
14christ
A lot and needs active cooling in my environmentAnyone tried using neutron player PCM to DSD 256 with the m17? can you give feedback on how much it heats up on balanced connection?
MusicalDoc8
Using more powerful gain or using low/mid?A lot and needs active cooling in my environment
14christ
Enhanced over earUsing more powerful gain or using low/mid?
MusicalDoc8
isn't that the one setting needing the fan?Enhanced over ear
Yes, it is.isn't that the one setting needing the fan?
Not necessarily, I never needed the fan.
Maybe not for IEMs but I wouldn't be so sure if you are driving a fullsized HP in DC mode and also pushing the SoC for DSD256 conversion.
I was today 1.5 - 2h in enhanced mode listening to LCD2 2021 closed back, forgot to engage cooling. M17 got fairly hot but didn't get any warning message.Not necessarily, I never needed the fan.
The truth is that I don't have difficult loads (Clear Mg, Arya, HD8XX etc) so maybe this is why I never needed the fan. (that I hate!)I was today 1.5 - 2h in enhanced mode listening to LCD2 2021 closed back, forgot to engage cooling. M17 got fairly hot but didn't get any warning message.
But I think the original question is about using in battery mode without fully pushing thr amplifier, e.g. using an IEM and realtime DSD256 conversion.
If I listen to Campfire Cascade, in over head mode (no DC), I never use fan. 4 4mm...The truth is that I don't have difficult loads (Clear Mg, Arya, HD8XX etc) so maybe this is why I never needed the fan. (that I hate!)
MusicalDoc8
How warm does it get? in the pocket or on the desktop?If I listen to Campfire Cascade, in over head mode (no DC), I never use fan. 4 4mm...
I am just keeping it on a aluminum stand without turning the fan on, volume 55-65, over head earphone mode. After 1h I can feel it north of warm but not very hot, I would guess 45-50C outside chasis.
Total: 12 (members: 0, guests: 12)
