[FiiO M17] Dual ES9038PRO, dual THXAAA-788+, dual power supplies, 9200mAh battery, 2 volume control modes
Jun 4, 2022 at 5:41 AM Post #4,037 of 5,690
Gotta keep the 99s since I'm Romanian :) , but my soul is with Sony. Got both their flagships, cans and IEMs. Simply spectacular with M17, both of them.
Jun 4, 2022 at 5:51 PM Post #4,038 of 5,690
Does anyone still have the popping or clicking noise issue during playback? I want to pull the trigger on one but this issue might potentially ruin my experience of the M17…
I still get them occasionally. They only happen for me at the start of tracks, normally at the start of a session, or after heavy skipping/track switching, and it is only ever one. So for example, I may get a pop or pause at the start of an album, but then the rest of the album is perfect.
It's a very minor issue for me and TBH, I wouldn't care if it was never fixed.
Jun 5, 2022 at 9:14 AM Post #4,039 of 5,690
When you feel the standard peli case won't cut it on long haul ....
Jun 5, 2022 at 9:57 AM Post #4,040 of 5,690
Jun 5, 2022 at 11:33 AM Post #4,041 of 5,690
Where did you get the foam inserts?
Foam base came from this
You can buy just the foam by itself and the piece of foam inside of the lid is silicone glued on to the rubber matting which comes with the peli case holds in place the charging cable so when folded protects the screen is just a 5mm piece of standard foam cut down, all fits snugly ( not tight ) and there's no movement, overkill I guess but I did drop a peli 1040 recently and it broke at the hinge and opened, luckily it was empty. But this case is super strong with vulcanised rubber edges. 👍
Jun 5, 2022 at 11:39 AM Post #4,042 of 5,690
Thanks!
Jun 5, 2022 at 3:05 PM Post #4,044 of 5,690
peli itself provide it for each size and model.
same here. i had 10+ daps so far and ALL had this "issue"... so for me it feels just normal.
Jun 5, 2022 at 7:31 PM Post #4,047 of 5,690
I sincerely doubt that as the width is a few mm short of naked DAP. If the leather case is on no way it fits...
Yes it does, snuggly with the case on. Perfect without the case. I have it so I know.
Jun 5, 2022 at 10:16 PM Post #4,049 of 5,690
My photos of the case above. Not bad for about $24 delivered. It fits the 7Hz Timeless in their case, the EIR-Z1Rs and the DAP under the divider.
