e-dub
WELL into this thing. It's pretty much the polar opposite of the X5mk2 I had before, but the little thing served me well and will be given to a friend this weekend.
What you need to consider first is what kind of form factor you need.I'm debating between the m17 and k9 pro.
My worry with the m17 is battery. How long do you expect the battery to last, before its not very usable anymore.
With the k9 pro I don't need to worry about that.
Also does the k9 pro have super capacitors the same as the m17?
They sound close enough but I cannot provide in depth comparison ATM.I've considered that, and if I get the m17 I will from time to time take it with me. And also take advantage of more power output.
But i worried about battery degradation.
I expect both to sound the same, can someone confirm this?
As you can configure with Android 10 à battery protection at 85% max, it should take years before altering it. Then with DC input, you bypass totally the battery. So I don't expect any issue with M17.What you need to consider first is what kind of form factor you need.
If you are not going to use the M17 as DAP and it is going to be stationary at your home then you better get the K9 Pro and save some money except if you don't have enough space.
If you decide for the M17 and use it at home with the DC in then you don't have to worry about the battery.
Dear friend,@FiiO
Since you haven't replied to my concern and problem, I will contact the support via mail now. I can't use my player for a week now.
Dear friend,Thank you, it seems I was downloading an incompatible file, this one worked fine.
Btw, I was hoping to see some UI improvements such as:
1) ability to see the current volume (or the back arrow) when album cover is white
2) an easier way to scroll through letters (currently they are on the right side and very narrow, making it frustratingly hard to manipulate)
Cheers!
