Kordonrules
Can someone tell me why I can’t make a post in this thread? I can only make a reply. Thank you.
I want to start a new post in this thread to ask a question, not a reply to someone else’s question.A reply is a post.
@FiiOjust did it.... nothing changed . i see once a short electricity flashing on the DC connector but nothing happens.
That would be great. I’m looking for feedback from anyone using the TRN BAX with the M17. How do you like them? Possibly compare them to the 7Hz Timeless?Maybe someone else can ask the question for you?
You have already done.Seriously?
NoA question re: "music only" mode. Is it possible to use something other than the Fiio player and still use the player in music only mode?
M17 weighs nearly 1.5 lbs. Your average smartphone weights less than .5 lbs. Just by eye, the M17 looks about 4x thicker than your average phone as well. I think your best option is one of those mounts that fit in a cup holder, but you have to take a careful look at the securing clamps to make sure they are thick enough. Fortunately, the M17 is not that much wider than a large smartphone.OK, I just ordered the M17, and I was told that it will be shipped by end of day tomorrow.
Question: Since I will be using it a lot in my car, does anyone know a good/secure car dashboard holder/mount for it?
Thanks,
thank you, in that case I already have at least 3 dashboard mounts for a it.M17 weighs nearly 1.5 lbs. Your average smartphone weights less than .5 lbs. Just by eye, the M17 looks about 4x thicker than your average phone as well. I think your best option is one of those mounts that fit in a cup holder, but you have to take a careful look at the securing clamps to make sure they are thick enough. Fortunately, the M17 is not that much wider than a large smartphone.
