Nice. Hoping to get my Steam Deck next month and will be happy to do A/B comparison with the M17 when it arrives.I would say that the M17 is much more like the "Steam Deck" - portable gaming console, which has enough power and futures to play games smoothly with a lot of fun, but with top notch PC (desktop device) you still going to get better resolution and more immersive experience. Overall M17 is really powerfull and joyful device for its portable form factor and futures.
[FiiO M17] Dual ES9038PRO, dual THXAAA-788+, dual power supplies, 9200mAh battery, 2 volume control modes
Ben86
- Jun 24, 2015
Does it have 3.5 mm audio jack?Nice. Hoping to get my Steam Deck next month and will be happy to do A/B comparison with the M17 when it arrives.
Good point, didn't even look into that. Probably Bluetooth onlyDoes it have 3.5 mm audio jack?
yes already try it and its sound so good, bit different with my desktop set up, but its sound so good.Yes, with HD650 over ear mode sounds really good! Even without balanced cable.
FiiO Music App V3.0.9 for M series players update now!
Updated in 2022-01-25
Changes and improvements about new Android APP are as follows :
1. Added a new theme: Technology (can be enabled in Settings -> Theme -> Custom background);
2. Upgraded the BT device control center to a brand new one(now called FiiO Control);
3. Added sorting by year;
4. Added support for DLNA-Emby service in Media Server(Emby/UPNP/SMB protocols are now supported);
5. Added Now Playing list in the Media Server playback menu;
6. Added new options: Max Volume Lock and Allow background Activity (can be set in Settings -> USB output);
7. Fixed the issue where the volume control would not work for some tracks in D2P output mode;
8. Fixed the issue where the DSD tracks might not be played properly (only white noise can be heard) while the Exclusive USB audio access mode is turned off;
9. Miscellaneous improvements on performance;1. Added a new theme: Technology (can be enabled in Settings -> Theme -> Custom background);
4. Added support for DLNA-Emby service in Media Server;
FiiO Music app-V3.0.9 for M series Android players: Click here
How to check the APP version of FiiO Music app:
From settings-About-VersionX.X.X
How to update the FiiO Music app in players:
Set the device to storage mode and connect to computer, drag the downloaded FiiO Music (.apk) to the device. Then disconnect the connection and enter ES file explorer/file manager, find the FiiO Music app in internal storage/sd card and click install.
Still not seeing 3.0.9 from the Google Play Store.
Would it be possible to to update via the store instead of installing the apk (for my M17, M11+Ltd, and android phone)?
Thanks.
just get inside fiio music then setting>>about>>updateStill not seeing 3.0.9 from the Google Play Store.
Thanks.
Dietmar Görtz
The M17 is fantastic.
But when will FiiO make a better case?
Case is not tight so air can go between and cool DAP better. But there will be some other 3rd party cases to purchase I am sure.The M17 is fantastic.
Dietmar Görtz
The case is too loose. It can be a little tighter.
And the bottom flap opens too easily.
Yeah I agree with bottom flap, should have been somehow better secured, always have feeling it might fall out of a case when carrying M17 around..The case is too loose. It can be a little tighter.
No, it has 3.5mm jackGood point, didn't even look into that. Probably Bluetooth only
Not had any issues myself, but would like to see a Van Nuys or Dignis case for the M17.The case is too loose. It can be a little tighter.
It turned out a great synergy with green frogs!)
Total: 9 (members: 0, guests: 9)
