2. Control buttons are too sensitive and can be pressed accidentally very easily and this has happened many times - it is annoying, actually.
That could be an issue, or not an issue. The problem here is the lack of a case and we are not able to test a real use case scenario, which is with the case.
For example, that was one of the things I hated with SP1000 and especially SP1000M. Those little buttons close to each other can be accessed and works well if there is no case. But if the player is in the case, because the buttons are so small and so close to each other, and if the player is in you pocket, it was for me just a matter of luck to find the right button and press it. It was sometimes even a problem when I am holding it in my hand! I would sometimes press two buttons at a time or press the wrong one. For KANN Cube inside a case, it anyway didn't fit my pockets but only an extra bag which I usually carry with me, so I needed to take it out and look at that I am pressing the right button. It anyway has bigger buttons, but still not the most comfortable layout inside a case.
Because we don't have a case with M15, we cannot see how the buttons work inside a case. Maybe someone with the case can comment here.
The best buttons I have seen on a player are on WM1Z.
