Nooborghini
Which albums would you play if the M15 could ?
Albums such as this but I would probably just want this done via USB- just curious how it would sound on the device, native.
https://www.nativedsd.com/albums/LWC1189-schumann-piano-quintet-op-44-and-piano-quartet-op-47
You can easily try it by:
- Connect your M15 to your computer as a USB DAC
- Either download the https://samplerateconverter.com/ and convert a very well recorded album to DSD512, and play it using foobar2000 (I haven't tried using the foobar2000 but played through HQPlayer). EDIT: https://www.sony.com/electronics/support/articles/00075146
- Or download the HQPlayer (https://www.signalyst.com/consumer.html) and use real-time DSD512 conversion
- In both cases play through M15 and check if you hear any difference.
- If you like, repeat it with DSD256 which should not be any different from DSD512
You can also try hard to find a DSD512 album and its DSD256 version and maybe also its FLAC version - and compare them all by playing on your computer with M15 in USB DAC mode.
My conclusion was, DSD512 is simply not needed on M15.
I was just curious on how it would sound, I would consider using it as a USB DAC- it just crossed my mind if I wanted this in my living room instead of having to set this up at my desktop and move files around etc.
I was actually going through this exact setup as I found out that it wouldn't read the 512 native! haha thank you!
