FiiO released a new beta firmware, announced on Facebook:
Hi, here comes the latest beta firmware for M11/M11Pro/M15.
Notice: this version is still under beta testing phase. If you have any problem, please feel free to contact us at
support@fiio.com. Any suggestions would be greatly appreciated.
Download link->
M11->
fiio-file.fiio.net/M11-ota-2020041802.zip
M11Pro->
fiio-file.fiio.net/M11Pro-ota-2020041802.zip
M15->
fiio-file.fiio.net/M15-ota-2020041802.zip
Update note:
1.Add MQA support for M11
2.Added displaying sample rates on the status bar (you can enable it in Settings -> Display -> display sample rates);
Note that this function is only available when playing music locally, and it does not work for the USB DAC, Bluetooth, USB Audio modes;
3.Added 'enter sleep with one click' function (you can find the 'enter sleep' icon on the home page and tap on it to have the player enter sleep mode);
Note that when this function is performed, the player will also close the apps running in the background and turn off the screen to enter sleep mode. After that it can only be woken up by pressing the physical button;
4.Fixed the issue where the audio will stop automatically after two minutes of playing in some apps when output in USB Audio mode.
5.Miscellaneous bug fixes.
[/CITAZIONE]
thank you
