That is correct.
Dear user,
Can the FiiO driver icon show up at that time? If not, please check via other usb cables and ports to check again?
Best regards
That is correct.
HelloDear user,
Best regards
Dear user,Hello
Does M11 Pro uses two dacs in line-out?
The shown circuit in the page of M11 Pro seems to show that it uses only one dac for 3.5mm PO. Is it the the same for line-out? Is one dac useless in this case?
M11 uses two dacs according to the shown circuit.
Hi, I had this problem once as well. A reset helped.Hello , my Fiio M11 Pro just die today after less a month. Im abile to turn it on ,only în i plug în charger, but its stop on Fiio"s logo. This is noi nice for a player that cost 800 euros.
Hi, I had this problem once as well. A reset helped!Hello , my Fiio M11 Pro just die today after less a month. Im abile to turn it on ,only în i plug în charger, but its stop on Fiio"s logo. This is noi nice for a player that cost 800 euros.
I looked for it in the net but couldn’t find any more... if I remember right, you must press the pause and the volume up or down button at the same time.How do i reset. Its not working.
From the manual:How do i reset. Its not working.
