I think that's the same leather case i have on my M11pro
really like this case since it fits tight.
I got a small gadget case that basically does the same thing at Staples for like $4 at their clearance shelf a few months ago. Got a couple of them. Currently using one gadget holder for my DX220 and the other for the M11pro. Both have cases as well. Just goes to show that not everything on Ally is a bargain, granted that gadget case/holder looks to be a better quality.
Pics of the case? Brand/model?
I haven't found a single deal on AliExpress, just chinese goods at their regular prices. Even the 11.11 sale seems like you would have to spend $1,000 to save $100 with coupons. lol
But be careful, it looks like the IEMs are gonna scratch up that glass when you close the case! That's how the back of mine got a tiny scratch. I used to wrap it up and put it in my pocket, and the cl2 scratched the back... still pissed...
Staples brand. Like I said it was on the discount rack. They had a newer version of it by the front of the store.
You can get that case on amazon as well, for a few $ more
https://www.amazon.com/DD-Portable-...ords=hifi+carrying+case&qid=1573004454&sr=8-1
I tuck the iem's under the meshing. Thanks for the heads up though. I usually only have one pair under the meshing pocket.But be careful, it looks like the IEMs are gonna scratch up that glass when you close the case! That's how the back of mine got a tiny scratch. I used to wrap it up and put it in my pocket, and the cl2 scratched the back... still pissed...
Yeah you can get that type of case on Amazon for about $7, it’s basically an external hard drive case. Works fine, except I’d want a case that keeps the IEMs (more expensive than the dap!) well away from the dap, with room to spare for charging/data cables, adapters, spare tips etc. I haven’t seen any case other than the DD (and the far more expensive but much fancier Dignis Attineo) that does this.I tuck the iem's under the meshing. Thanks for the heads up though. I usually only have one pair under the meshing pocket.
I have no problems!Hello all!
The problem with the sound loss is still not solved?
I'm worried about this, I plan to buy this DAP.
Hello all!
