You may try Volume Slide Trigger app. This help solve the problem.Thanks.
I am already in Hi Gain mode. I am curious why it would make a difference to the sensitivity of the volume control wheel which gain mode I'm in.
FiiO M11Pro | Dual AK4497 | THX AAA 78 Headpone Amp | 5.15" 18:9 720P | Exynos 7872 | 3G Ram+64G Rom |
- Thread starter JamesFiiO
- Tags
- fiio fiio m11 pro
saldsald
- Dec 9, 2016
So I am using the leather case that came with the 11 Pro and now I can't separate the case from the device...... Please help...
There is no case tat comes with M11 Pro, not even the clear silicon case with M11.. What you might get is the Leather case tat suppose to be for M11... which is too tight fitting for M11 Pro
saldsald
- Dec 9, 2016
I mean came as a bundle not in the box......There is no case tat comes with M11 Pro, not even the clear silicon case with M11.. What you might get is the Leather case tat suppose to be for M11... which is too tight fitting for M11 Pro
TubeStack
- Feb 26, 2009
I have a leather case on my M11P that’s meant for the M11, it’s fine on mine.
TubeStack
- Feb 26, 2009
And I use the term”leather” loosely...
bcaulf17
- Nov 29, 2016
I’m actually having somewhat of a similar issue; seems that the fist half second of the first song on HD albums are cutoff. Even if I go back and start the song over, it does it. Using the FiiO Music app.Mine works well, with the exception of skipping the first second when starting a new album or song that’s on a different album than the previous track, as I’ve previously mentioned.
It’s now routine/muscle memory for me to start a song and then immediately hit the back button to restart it from the actual beginning.
Aside from that though, no other issues. Awesome device!
saldsald
- Dec 9, 2016
Oh true, that is not leather at all, lol. I think I gotta try to force the M11P out...I need access to the SD card slot...
I take one of those wood laundry pins with a spring and use a knife to sharpen the flat end. Not so sharp that it's too thin but enough that it will slide in between the case and the M11Pro. Then use it to pry the case away from the M11Pro. The wood works well so as not to damage anything.
saldsald
- Dec 9, 2016
Thanks for the inspiration! It worked with a wooden chopstick!I take one of those wood laundry pins with a spring and use a knife to sharpen the flat end. Not so sharp that it's too thin but enough that it will slide in between the case and the M11Pro. Then use it to pry the case away from the M11Pro. The wood works well so as not to damage anything.
Holy! I've got to go back to the shop soon to have a good chat
senorx12562
Although the idea that a leather(ish) case might become stuck to the dap never occurred to me, the heat coming from the back of the m11p has made me wonder whether the fiio branded case with the metal vents on the back is designed that way because of the metal's heatsink ability. I'd be concerned about the long term effect on the electronic components from heat build-up with a fully enclosed case of any material. I'd like it to last, though that is not gonna happen if I drop the thing.
Fresh from FiiO-philes @WianFiiO
Get an early access of the M11/M11 Pro/M15 beta firmware:
Notice: this version is still under beta testing phase, if everything works fine, we will release the offical firmware in a few weeks. And if you have any problem, please feel free to contact us at support@fiio.com. Any suggestions would be greatly appreciated.
Download link:
M11-> http://fiio-file.fiio.net/M11-beta-20201223.zip
M11Pro-> http://fiio-file.fiio.net/M11Pro-beta-20201223.zip
M15-> http://fiio-file.fiio.net/M15-beta-20201223.zip
Update note:
1. Added full-screen album cover display and spectrum display (can be set in FiiO Music settings -> Theme -> Now playing menu);
2. Added a new function of disabling the volume knob (This function is only for M15, it can be set in Settings -> Audio or in the pull-down shortcuts menu; And please note that when the volume knob is disabled, turning the knob will not directly adjust the volume but trigger the volume slider on the touch screen. In this case, you can adjust the volume using the volume slider, or control it through FiiO Link);
3. Added sorting by artist under the Album category;
4. Added displaying the total number of tracks in the track list;
5. Added a new function of switching between album list display or track list display under the Artist/Genre category;
6. Added support for using any image file as custom album cover;
7. Added a shortcut for toggling the All to DSD function in the pull-down shortcuts menu;
8. Added file sorting in FiiO Link mode;
9. Added sliding on the bottom control bar to skip tracks in FiiO Link mode;
10. Miscellaneous bug fixed.
Download link:
Update note:
Pro version doesn't work. Starts updating and about a third the way in, finishes and the firmware is still 1.0.3. This is using the links from FiiO-philes FB page. It would get about a third the way through installation and then reset showing 1.0.3.
Version number was not updated yet, so it's correct that you still see 1.0.3. And FiiO Music app should have been bumped one up from 3.0.2 to 3.0.3
Total: 8 (members: 0, guests: 8)
