[FiiO M11 Plus LTD/M11 Plus] THXAAA-78,Android 10, 2.5/3.5/4.4 Powerful Output/4.4 LO output, Dual AK4497/ES9068AS DAC chips, 4GB RAM,64G Flash
Jul 8, 2021 at 5:23 PM Post #511 of 2,990
There is mine.
Jul 8, 2021 at 9:54 PM Post #512 of 2,990
Where did you buy it? Seems you got it super fast! How's it do with heat? The included case seems to get quite hot.
2👈🔐DAOmX8kLXgD🗝 https://m.tb.cn/h.4y1k8Ey?sm=f050be ~这个商品很不错,我还有一张【10】元,限量优惠I券送给你,快来看看!【FiiO/飞傲SK-M11Plus便携无损音乐播放器真皮保护套防滑耐磨皮套】
On Taobao. That's the direct link.
Jul 9, 2021 at 8:49 AM Post #516 of 2,990
I had to cut out the panel from this Fiio HB4 case to fit the player. I added a little block of foam so I can keep the iems plugged in. My idea is that countless times of plugging in and out will wear out the plug and socket. Might be completely wrong. The m11 plus is a big boy. Too big to fit the HB4 case.
personally I think it would be great to see Fiio design a flat headphone like box that fits the m11. With cutouts to keep it plugged. Some routing to coil the wire. The whole thing like a zippered Eva type case.
I tread to make one form an old case and a block of foam but failed miserably.
Jul 9, 2021 at 8:50 AM Post #517 of 2,990
76825D8D-DA5D-4647-BEAB-F33BB10FD8BD.jpegI had to cut out the panel from this Fiio HB4 case to fit the player. I added a little block of foam so I can keep the iems plugged in. My idea is that countless times of plugging in and out will wear out the plug and socket. Might be completely wrong. The m11 plus is a big boy. Too big to fit the HB4 case.
Here’s a closeup of the foam block. This way the plug can’t smash into the wall of the box. It’s floating free.
Jul 10, 2021 at 10:27 AM Post #519 of 2,990
Is it possible it's the screen protector and not the screen? Just spit-balling.
Unlikely - typically its when something behind the screen like dust get trapped during manufacturing and puts pressure on a spot
Jul 10, 2021 at 12:30 PM Post #520 of 2,990
Is anyone finding the 3.5mm jack a bit warmer more relaxed sounding compared to the 4.4mm? Tested with few different iems, it’s not as forward sounding and as hard hitting so it suits me better- I think anyway...
Jul 10, 2021 at 5:05 PM Post #524 of 2,990
Maybe. I've never ever personally heard that myself though. Doesn't mean it's not a thing though. I find extra power just increases the noise floor and makes it sound worse.
I agree it sounds worse if the headphones impedance is too low for the output. Worse but beefier (in my experience) I prefer less power for sensitive headphones, which is probably logical.
Jul 10, 2021 at 5:08 PM Post #525 of 2,990
Yeah exactly. I use IEMs with my DAP only. If I used power hungry headphones maybe I'd feel different.
Funny enough I've been moving away from headphones over to IEMs even on my Desktop setup to be honest. Don't know why, just don't enjoy headphones as much now.
