[FiiO M11 Plus LTD/M11 Plus] THXAAA-78,Android 10, 2.5/3.5/4.4 Powerful Output/4.4 LO output, Dual AK4497/ES9068AS DAC chips, 4GB RAM,64G Flash
Jul 6, 2021 at 4:59 PM Post #496 of 2,984
Yeah I'll think about it. I'm in no rush. Do you know where to get replacement foam tips? I assume just comply? Can't find any others and silicone is a no go for me.
I think these are special Sony foam tips, i.e. not really foam but other material which should last a long time.. but lets see
Jul 7, 2021 at 1:53 PM Post #497 of 2,984
Some days of hearing are gone.
The M11 Plus seems to get better for me, soundwise.
For build quality there is a third flaw on my M11 Plus ☹️
One spot of the display is brighter than the rest. Annoying for a device that cost 799€.
Think i must return the player and not sure if i can get a new one. 😭
Jul 7, 2021 at 2:13 PM Post #498 of 2,984
For that money I would return it. New better and more shiny daps will come along.
Jul 7, 2021 at 2:33 PM Post #499 of 2,984
Sounds like maybe you got a bad one. It happens, even with the strictest quality control. For what it’s worth, I have a black one and a stainless steel one and they both look pretty perfect to my eyes, but I guess it’s luck of the draw. You’d be justified in returning it.
Jul 7, 2021 at 4:18 PM Post #500 of 2,984
I also have a white spot, but it's on a different location. It's not a massive one but it's annoying. My M11 Pro has another issue with its screen like an oval shaped imprint on it. Seems Fiio can't get it's screen QC under control, or perhaps using cheaper panels
Jul 8, 2021 at 9:20 AM Post #501 of 2,984
The new FiiO case came yesterday. :)
Jul 8, 2021 at 11:31 AM Post #505 of 2,984
Jul 8, 2021 at 5:23 PM Post #510 of 2,984
Is it possible it's the screen protector and not the screen? Just spit-balling.
