takeitblue
Next batches will be probably with ESS dacs
@FiiO any comments on this?
Dear friend,Does anyone know if FiiO will do an announcement for a new drop to the public of M11 plus LTD?
It seems at the moment only a few retailers have very few units and we are sharing with each other here about availability. I wonder if FiiO will just keep a slow trickle of units fed into the distributors or they will release a larger chunk supply for those of is that haven't had a chance to purchase.
Dear friend,Next batches will be probably with ESS dacs
this is the only reason im bummed out that i bought the pro a month before they announced the plus but seems like pulling teeth trying to get your hands on a plus so perhaps its for the better. probably something better will be around down the line in a couple years if/when i can justify an upgrade
- M11+ with its Android 10 is vey fast and makes the M11 Pro with that ancient Samsung SOC and A7 feel like a Motorola flip phone (OK, that’s a little too much hyperbole, since the M11 Pro never felt that slow to me, but the M11+ feels like a modern phone and never lags)
I would but it seems like an impulse buy on my end. I just got into the audiophile game with the FH3+Q3 and on the M11Pro now. Honestly I'm looking to spend money on some E-MU Teaks to get into something more serious than my VMODA M100s to complement my FH3's. And even then I'd sooner upgrade the FH3 iem's to the excalibur or monarchs before considering a DAP upgrade. Other than the android 10 im pretty happy with the pro, i definitely see value in these devices with my experienceKeep trying, you will not be sorry. I love mine very much.
Just use another app. Most of the ones I've tried bypass the SRC. Don't need UAPP at all unless you like the specific way it changes music.I got an issue with UAPP, and the app can not detect the DAC and bypass the Android System Audio. I'm not sure this issue is related to the firmware, or the developer's app needs time to make this app compatible with the new device.
I just got the Fiio M11 plus about 2 weeks, and the default firmware version is 1.0.2. I don't use any streaming music services and only playing music on the SD card.
Use the hires driver, go to settings tap it to open,top of page tap that select hi-res driverI got an issue with UAPP, and the app can not detect the DAC and bypass the Android System Audio. I'm not sure this issue is related to the firmware, or the developer's app needs time to make this app compatible with the new device.
Thanks, I just want to know everyone else got the same issue as me and figured out how to fix this problem, UAPP is just one of mine optional. I mostly use Neutron Music, and Neutron also got some small problems with M11 plus, and maybe need a new update, but it still works fine.Just use another app. Most of the ones I've tried bypass the SRC. Don't need UAPP at all unless you like the specific way it changes music.
Thanks for your advice. I already did that, but still not working.Use the hires driver, go to settings tap it to open,top of page tap that select hi-res driver
search for bit perfect mode and select that,with nuetron I have to select follow source,put it in 64bit mode then it works fine.Thanks, I just want to know everyone else got the same issue as me and figured out how to fix this problem, UAPP is just one of mine optional. I mostly use Neutron Music, and Neutron also got some small problems with M11 plus, and maybe need a new update, but it still works fine.
I also like the sound of the Fiio Music app, but I don't want to use it because this app still has bugs and is laggy sometimes.
If UAPP and Amazon Music don't bypass Android on the M11 Plus, and it also overheats, then I think I will save for an iBasso DX300 or another LG V50 phone...
I also did that too, but still not working. Maybe I will wait for the next update and using Neutron at the moment.
