I have the Ibasso dx300 beautiful dap as well as numerous FiiO Daps, only bought it for the thx 78If UAPP and Amazon Music don't bypass Android on the M11 Plus, and it also overheats, then I think I will save for an iBasso DX300 or another LG V50 phone...
[FiiO M11 Plus LTD/M11 Plus] THXAAA-78,Android 10, 2.5/3.5/4.4 Powerful Output/4.4 LO output, Dual AK4497/ES9068AS DAC chips, 4GB RAM,64G Flash
- Thread starter FiiO
I have mine with me today at work, let me check and see if UAPP is giving me your issues.
I also did that too, but still not working. Maybe I will wait for the next update and using Neutron at the moment.
dricas_007
Today I just collected my FiiO M11 plus Ltd, heard it arrive with very limited stock at my reseller in Singapore
Only issues l have is Amazon HD not bypassing SRC, FiiO been quiet for the last three weeks, praise em and they'll respond, this will be my last FiiO product,QC has been lacking on many products.I have mine with me today at work, let me check and see if UAPP is giving me your issues.
UAPP seems working fine on my m11+.
Does it not run at all on yours?
It's work fine through Android audio, but when using the hi-res driver, there is no output sound.UAPP seems working fine on my m11+.
I have selected hires driver:
Select uapp setting > Internal audio driver > HiRes Direct driver
That works fine for me, although I don’t know how to tell if it is using the m11+ audio circuit, but it sounds the same as if play from the Fiio app.
If it is a software issue, perhaps a reinstall of uapp or even a android reset could save it?
Also, don’t forget to enable WiFi before running uapp during the first 24 hours after installing it. UAPP checks the license in the 1st 24 hours.I have selected hires driver:
Hope this helps.
Thanks, I did the same settings as you, but still nothing changes. For now, I'm using Neutron instead and wait for the next update of UAPPAlso, don’t forget to enable WiFi before running uapp during the first 24 hours after installing it. UAPP checks the license in the 1st 24 hours.
Hope this helps.
Clear the cache in the app,than storage, reopen app, import,go to settings,set hires driver, bit perfect,see if it works.Thanks, I did the same settings as you, but still nothing changes. For now, I'm using Neutron instead and wait for the next update of UAPP
Thanks for your help, but it is still not working. Also, I tested with Apple Music and working perfectly
Apple works on mine too,Amazon HD stuck at 24/48
Joseph Lin
- Nov 8, 2016
i was thinking of buying it for Amazon HD now I have 2nd thought.Only issues l have is Amazon HD not bypassing SRC, FiiO been quiet for the last three weeks, praise em and they'll respond, this will be my last FiiO product,QC has been lacking on many products.
Finger Fish
Get a DX300 instead. It's obviously a different price bracket, but it's great.i was thinking of buying it for Amazon HD now I have 2nd thought.
stock3jacob
- May 3, 2011
Digital audio out. I want to connect my M11 Plus directly to my car stereo through USB. The Fiio documentation and website are worthless, as I can not decipher the lackluster and poorly translated directions. What setting would I use for this? Bluetooth is fine and all.....but a hardwired connection would do much better I would think with my higher quality audio files.
