LamerDeluxe (tm)
I have the same issue, it makes the DAC unusable for creating music or indeed, as you note, watching videos. This was already an issue with my X7 MKII, which has a shorter delay with higher sample rates, which indicates that the buffer length is not adjusted for sample rate.@FiiO Team,
Please let me know if you had a chance to find the cause of the USB DAC 300ms delay and if it is possible to fix that with a firmware update.
Thank you!
Meanwhile, both my Zorloo Ztella 1 and 2 have very low latency, without a custom driver, or even supporting ASIO and work fine for creating music. I don't remember my iBasso and Apple USB-C DACs having a large delay either.
