Jujoe
So what is the M15 supposed to be? We seem to have information on the M11 Pro, but what is the next iteration "up"?
Dual AK4499 and a Korg Nutube and THX AAA but this just a guess
My only issue with neutron. Button presses on M11 are delayed a couple seconds, and if I pause a track via mic control, if I wait more then a few seconds to press again, then I can never unpause via button press. Neither the mic control or the physical DAP buttons work. You have to go into the software and press play. This is how my phone works also with neutron, so I am assuming its a software issue.On Neutron, does fast forward/rewind work on M11? For me if I press and hold next button (on X7II) it just skips a couple of tracks rather than fast forwarding.
I thought I'd share a video of the dangerous noise issue that some of use are experiencing with the M11.
This video shows the bug/issue where the M11 plays excruciatingly loud noises when you hit play when the device is in standby mode.
The noise doesn't stop when you hit pause - only when you unplug the jack.
Lucky I wasn't wearing my IEMs when it happened this time!
This happened to me as well.
Series of events so FiiO can find out where the issue is coming from.
1) IEM plugged into 2.5mm balance
1) USB plugged in to charge
1) Device was on standbuy
2) I turn on the device and hit play
3) extremely loud static noise from my IEMs
4) hitting pause doesn't work
5) had to unplug headphone
6) plug back in and it was fine again
I'd hate to lose my hearing over this bug.
I was using Tidal.Sh1t sorry you have also had this issue
What was the file type you were playing and did you have resume or all to dsd enabled?
I was using Tidal.
All to DSD - not enabled
Yeah, seems like an annoying issue even though it's my first time experiencing it.Thanks for the info.
If you are having this issue via Tidal sounds like a system wide issue and not file or player related.
I now am starting the music without having any headphones on my head of fear of this happening to me
@FiiO do you have any news on this or when we can expect the next firmware?
I doubt the M11 can output multichannel files.M11 set to SPDIF output
Playing a 6 channel FLAC file of Dark Side of The Moon using FiiO music app
Marantz is only getting 2 channel input
Anything I'm not doing correctly ?
