Jujoe
Congratulations!) How are your impressions? There is a difference in comparison with FH5 ?
Thanks, I have only had an hour and a half, still testing the filters and my test playlist
I also don’t understand why Fiio ignores your question. I think in any case, Fiio representatives need to give an answer, otherwise it looks very strange.
There's a technical reason behind it.
Very nice.
Sound?
Cashback ?
Hi, we have already verified this issue, from the preliminary analysis, this is caused by a bug and can be solved by firmware update.I also don’t understand why Fiio ignores your question. I think in any case, Fiio representatives need to give an answer, otherwise it looks very strange.
Thanks for the answer! Let's hope for a solution to the problem. We are waiting for a new firmware.Hi, we have already verified this issue, from the preliminary analysis, this is caused by a bug and can be solved by firmware update.
Now we are still in further confirm, we will release a update as soon as possible once we solve it.
Thanks for the answer! Thanks for the answer! Let's hope for a solution to the problem. We are waiting for a new firmware.
Yes it is. I suspect modern batteries handle the fast charging better, but unless I am mistaken fast charging still has adverse effects on the batteries longevity.Another thing...
But isn’t it better for the battery to charge slowly? At least for Li-po batteries say so ...
I'm starting to think I'm the only person who doesn't listen to Run the Jewels... (Nothing against them, just never really listened to them)Boom New toys
I posted info about this earlier in the thread .HiBy, FiiO, Hugo, etc all report 88.2 There's a technical reason behind it.
https://www.mojo-audio.com/blog/dsd-vs-pcm-myth-vs-truth/ This may be why. Lots of good info there.
Hope it's ok to jump in here. I have FH5 and FH7 and recently bought the M11 to go with FH7. Several weeks in, I can confirm that the FH7 is a great match with the M11. Very revealing and dynamic, great soundstage. Smooth sounding yet articulate. Never fatiguing. Over the FH5, the FH7 is a clear step up, with much greater clarity and definition of space. The FH7 sound much more alive than the FH5.Congratulations!) How are your impressions? There is a difference in comparison with FH5 ?
Probably have to buy FH7Hope it's ok to jump in here. I have FH5 and FH7 and recently bought the M11 to go with FH7. Several weeks in, I can confirm that the FH7 is a great match with the M11. Very revealing and dynamic, great soundstage. Smooth sounding yet articulate. Never fatiguing. Over the FH5, the FH7 is a clear step up, with much greater clarity and definition of space. The FH7 sound much more alive than the FH5.
