[FiiO M11] Android 7.0, 2.5/3.5/4.4 Powerful Output, Exynos 7872, Dual AK4493 DAC chips, 3GB RAM, WiFi, Two-way LDAC
Aug 13, 2019 at 3:54 AM Post #6,017 of 9,270
Aug 13, 2019 at 3:55 AM Post #6,018 of 9,270
Dear friend,
If you are convenient, please send the music to us for check? After turning on the all to DSD function, you will get noise when using Tidal app?
Best regards
Hi. Yes, I get the noise only in Tidal app when I turn on "all to dsd". And it is more noticeable with certain songs (Patricia Barber - Too Rich for My Blood). I did factory reset and updated everything to latest, including Tidal.
Aug 13, 2019 at 3:58 AM Post #6,019 of 9,270
Aug 13, 2019 at 4:01 AM Post #6,020 of 9,270
Dear @FiiO friends,
Can you answer this?
I'm going to repost this here since I just noticed the devs for Neutron just discoverd the same thing... :grimacing:
@JamesFiiO @FiiO I'm on the latest firmware and I've just confirmed via logcat what someone said early in the thread (can't find it anymore). Even if I can play DSD256 files, the actual output is 16-bit / 88.2KHz instead of 24-bit / 352.8kHz. This is happening even in the latest version of the FiiO App. When is this going to be fixed and why does the FiiO App lie about the sample rate?
And I don't think there's an answer yet from @FiiO or @JamesFiiO (at least acknowledging the problem and explaining why FiiO Music shows a false output...).
Info from Neutron: DSD256 is not supported by firmware and FiiO Music player outputs DSD256 as 16/88200 PCM according logcat logs.
Aug 13, 2019 at 4:05 AM Post #6,022 of 9,270
Another thing...
But isn’t it better for the battery to charge slowly? At least for Li-po batteries say so ...
It can help the life span, well if the guys I speak to are to be believed. I am thinking of using a 5v 1a charger :p
Once again tho its an old phone charger
Aug 13, 2019 at 4:09 AM Post #6,023 of 9,270
Dear friend,
Thanks for your kind feedback. But I failed to reproduce the problem you mentioned.
1. Maybe you could try to wait some time longer after selecting all the music files in a playlist and clicking the 'add to playlist' icon?
2. Are those music files located in the M11 still? And please click the wifi music transfer icon instead of the word to try again?
If the issue remains, could you please provide more detail to us via support@fiio.com? Thanks in advanced!
Best regards
Ok yes maybe it would help to delay more before selecting add to playlist, but it's still a bug.
No worries my side, i've worked round it by selecting 100 or so faves at a time and adding them to playlist then removing the fave tag.
Aug 13, 2019 at 4:09 AM Post #6,024 of 9,270
I was thinking have you tried all the other USB ports in your pc? I have a powerd usb port it caused issues in the past.
Aug 13, 2019 at 5:11 AM Post #6,025 of 9,270
Dear @FiiO friends,
I also don’t understand why Fiio ignores your question. I think in any case, Fiio representatives need to give an answer, otherwise it looks very strange.
Aug 13, 2019 at 5:22 AM Post #6,026 of 9,270
Dear representatives of the company Fiio, I ask you to confirm or deny information about the support problem DSD256 "DSD256 is not supported by firmware and FiiO Music player outputs DSD256 as 16/88200 PCM according logcat logs." Your silence entails new questions.
Aug 13, 2019 at 5:29 AM Post #6,027 of 9,270
SPDIF output 3.5mm port(shared PO),DSD64/128,384kHz/32bit,DoP/D2P from the M11 site no mention of dsd 256
https://www.fiio.com/m11_parameters
But I see it is on some other parts
With the USB audio out, you don’t have to stop the music
The M11 can support outputting a wide variety of formats through its USB connector, including DSD256, DoP/D2P, and native DSD modes. Simply connect the M11 to an external decoder, and you have a portable jukebox capable of delivering excellent sound wherever you go.
https://www.advancedmp3players.co.u...h_Resolution_Lossless_Music_Player.15340.html
Aug 13, 2019 at 5:41 AM Post #6,028 of 9,270
The thing is its not just my question. I believe there's others who asked that, plust Neutron is reporting the same "issue". And I guess people who has paid for DSD256 files might want an answer. Anyways it's @FiiO 's fault if they don't adress this, there's people that might want to think about buying it before there's an answer, plus there's some others that could just return the player...
Buy hey, I tell you what's going to happen. FiiO is going to reply: "Hey, we will report this to our engineer" or "Hey, please send us the DSD256 files". Hehe.
Aug 13, 2019 at 7:37 AM Post #6,029 of 9,270
Boom New toys :)
